grinding when downshifting to 2nd
so occasionally my car will grind into gear when i down shift into second like if im about to make a turn or take a sharp exit ramp or w/e...clutch is obvi all the way down and ive never had this prob b4...has started in the last couple days...
any ideas??
any ideas??
ok so then what do i do when im making turns around town?? leave it in 3rd and jerk around the corner like a n00b or stop and put it in first??
and no im not rev matching cuz i suck at doing that and thats what the synchros are for
it never does it upshifting into second...only on the downshift
is this under the powertrain warranty??
welcome to the world of the f23/f35 tranny.
Its covered under warranty....mine is currently being worked on.
edit:
almost 50 signatures in less than a week.
oh and learn to rev match.. it's easier on the tranny anyway..
it's not that hard if i can do it
mine was doing it when my clutch master cylinder was fucked.. but since i got that replaced i rarely ever grind .. and when i do i usually know it was my ******* fault
ive never had a clutch fail either....EVER
for the life of a transmission, even learning ive never destroyed one or needed to replace one for the life of the vehicle.
i get 2nd gear grind.
Only reason im replacing my clutch is because they are replacing the transmission under warranty and its a cheaper "just incase".
