HackAbuse's Car is Down
Old Nov 1, 2007 | 11:59 AM
HackAbuse's Avatar
Got in my car this morning and cranked the engine.
Crank, no start.
Crank, no start.
Crank, no start.
Crank, run. putt, putt, putt, squeal, putt, putt, putt.
Also, all I can smell is unburnt exhaust fumes, so it's DUMPING fuel
You get the general idea.
I shut of the car and restart. Same result.
I disconnect the battery to reset the PCM. Same result.
Called GM Roadside and the car is getting towed within the hour.
I'll try to get a video of it (trying) to run before it's towed.
I'm pretty sure the PCM is toast
Old Nov 1, 2007 | 12:05 PM
lil_kano's Avatar
why would it be?
Old Nov 1, 2007 | 12:08 PM
CobaltDude06's Avatar
damn hack that sucks hope u get the balt up and running
Old Nov 1, 2007 | 12:10 PM
Survivor058's Avatar
u should prolly take my shiftplus out of there before u let GM play with ur car
Old Nov 1, 2007 | 01:07 PM
HackAbuse's Avatar
Way ahead of you man
Originally Posted by lil_kano
why would it be?
Why? I don't know, but based on the symptoms, that's my educated guess.
Well i just got here to the dealership, we started it up one last time before we towed it, and I had a flashing check engine light.
Wish me luck
Old Nov 1, 2007 | 01:08 PM
SSteveSC's Avatar
eek.. hope it turns out alright
Old Nov 1, 2007 | 01:09 PM
RuSSo-29's Avatar
luck
Old Nov 1, 2007 | 01:11 PM
HackAbuse's Avatar
By the way, I got a video of the car "running", so you all can enjoy that when I stop back home and get my digicam cable
07LaserBlueSS's Avatar
Hope everything works out for you man!
Old Nov 1, 2007 | 02:47 PM
RuSSo-29's Avatar
updates....?
Old Nov 1, 2007 | 03:33 PM
HackAbuse's Avatar
They called me back a little while ago. They're blaming the problem on my Bosch Platinum +4 plugs. They are "the wrong plug for the car"
"They fouled out and ruined the coil pack"
They want $380 to fix it
Old Nov 1, 2007 | 03:35 PM
CobaltVenomSS's Avatar
**** that!!!
SSRich's Avatar
WoW we need to put up something about this didnt somebody else get screwed from the dealer about the Bosh Platium +4 plugs.
Old Nov 1, 2007 | 03:36 PM
Moza13-'s Avatar
thats bullshit
Old Nov 1, 2007 | 03:38 PM
an0malous's Avatar
lets not jump to conclusions here.
id love to see the plugs if thats possible....and what gap you had them at.
Old Nov 1, 2007 | 03:41 PM
HackAbuse's Avatar
They don't gap. They're non-gappable plugs.
trent_ky's Avatar
they will look for anything they can to not replace under warranty...*******
Old Nov 1, 2007 | 03:42 PM
HackAbuse's Avatar
Originally Posted by Moza13-
thats bullshit
Tell me about it.
A coil pack costs $25 bucks from the junkyard. I still have to stock plugs at my parents house. and it takes 10 minutes to swap all four plugs and the coil pack, so I don't know where they're coming up with $380
I'm going to take a LONGG inquisitive look at that invoice when I get it
Old Nov 1, 2007 | 03:44 PM
MISSMATCHEDFACES's Avatar
maybe u just blew an o-ring on one of the injectors
HackAbuse's Avatar
At least GM paid for the tow
Old Nov 1, 2007 | 03:45 PM
Moza13-'s Avatar
well when their heads are up their asses its a little hard to get it done in 10 minutes, i mean cmon man give em a break, literally they might need a soda or two inbetween the 2nd and third plug
skymynx's Avatar
good luck tell them no thanks go to hell
Sunburst_SS's Avatar
well are they getting you parts from a junkyard?
Old Nov 1, 2007 | 03:46 PM
HackAbuse's Avatar
If they did i wouldnt mind
Old Nov 1, 2007 | 03:48 PM
MarcS's Avatar
The Stig
I've had that problem twice with stock plugs. One 100% stock and one with my 3" pulley. Both times stock plugs.
Theres something about the cold that the coil packs don't like.
The coil modules are not cheap, that's why the price is so high. It's easy to install. Just order the part from them and install it yourself.
