Harmonic balancer
Old Jul 14, 2016 | 11:04 PM
Andres235's Avatar
Harmonic balancer
Has anyone had problems with deleting this part and car giving p0341 engine code?
Old Jul 15, 2016 | 12:28 AM
Sharkey's Avatar
what do you mean by deleting the balancer?
Old Jul 15, 2016 | 12:33 AM
mrbelvedere's Avatar
its a dampener not a balancer and if you remove it bad **** happens
Old Jul 15, 2016 | 06:20 AM
Andres235's Avatar
The thing is when a purchase the car the previous owner told me that he just recently deleted the balance shaft of the car. I was wondering if maybe the balance shaft are connected with de crank sensor and that's why is giving me the code of P0340. I found that some Gm engine have the sensor working with balance shafts
Old Jul 15, 2016 | 09:20 AM
jdbaugh1's Avatar
Balance shaft is completely different from the harmonic balancer/crank pulley. Also googled P0340 and it comes up with "camshaft position sensor malfunction"
How does the car run? You have to take of the timing chain to get to the balance shaft chain. Is there a possibility that the previous owner didn't get the cams timed correctly?
Old Jul 15, 2016 | 09:41 AM
yellowsupercharged06's Avatar
its a balance shaft delete as jdbaugh1 is saying above.
I can guarantee that the reassembly of the cam shafts and sensor was not done correctly.
Old Jul 15, 2016 | 10:58 AM
Andres235's Avatar
I re días the Timing of the engine and the cams. When I bought the car check engine was off. Sensors are new, car runs pretty smooth once it starts. Just looking for an solution
Old Jul 15, 2016 | 05:54 PM
P0341 Camshaft Position (CMP) Sensor Performance -PCM
check the wiring with a meter
Old Jul 15, 2016 | 05:56 PM
Andres235's Avatar
What is the reading that I suppose to get?
matthud
Jun 9, 2016 11:52 PM
CobaltCraig
Jun 4, 2016 06:22 PM
garythomak
May 16, 2016 08:01 PM
garythomak
2.2L LAP Performance Tech
May 16, 2016 02:36 PM
Timnman
Apr 18, 2016 12:53 AM
