Headlight Problem
Old Apr 5, 2010 | 09:51 PM
Brandon22685's Avatar
Headlight Problem
The last 2-3 days my car has been acting weird. Sometimes my headlights stay on even when I turn auto lights off. Sometimes my headlights stay on when the rest of my lights are off including the rear lights and my car is locked when the headlights are suppose to turn off. For me to manually turn my headlights off, I have to play vigorously with the light switch to make the headlights FINALLY turn off. What in the world is going on? Keep in mind that I pulled the DRL fuse closely a year ago. That is, if the DRL fuse plays any part in this...
Old Apr 5, 2010 | 10:03 PM
BumbleBee's Avatar
mine stay on for like 15 seconds when i lock it up and walk away if this is what you are referring to?
Old Apr 5, 2010 | 10:07 PM
ecot3c inside's Avatar
on my saturn I had to pull 2 relays to turn off the drl. I pulled the actual headlight relay and the drl relay. You would think the headlights would not work when switched on when you pull the actual headlight relay but they do. Try pulling your actual headlight relay.
Old Apr 6, 2010 | 08:54 AM
Coblasts's Avatar
Wasnt there other guys that had this problem caused by water intrusion into the under hood fuse box.
Old Apr 7, 2010 | 08:58 PM
Oh no BumbleBee, how about try 30mins to a 1 hour. I was in the house and my fiance' comes home and tells me that my headlights are on. I was like huh? So I walk outside and every light is off except my headlights.
turbochargedss2012
Sep 20, 2023 12:17 PM
yellow dragon
Sep 28, 2015 09:49 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
