heater
heater
ok, so today i used my heater in car and i dont know if this is a problem or a good thing. its to dam hot . so hot when i touched the vents i taught i was going to get 3rd degree burns lol its like a furnace
Don't forget our cars run in the 190-220 degree range, if you don't have COLD air going into the heater it's gonna come out real hot because it is the engine coolant heating the air. What was the outside temp when you had it on, I'm assuming you had it turned all the way to the hot end of the dial? Unless it was less than 50 outside or it was not all the way to hot, I'd considder it pretty normal.
