Help before i blow up my car.
Just did exhaust got a header/dp and full catback all 3" shortly after the car started going into limp mode. its been happening more frequently over the past couple days its to the point i cant keep it out of limp mode for more than 5 mins. Throwing code P2138 and P2122 dont think exaust should cause that checked all connectors at throttle body and pedal they wern't loose also cleaned the throttle body that worked for about 10 min. I need help before i blow my car up.
P2138 Accelerator Pedal Position (APP) Sensor 1-2 Correlation
P2122 Pedal Position Sensor*1 Out of Range Low
car has 35k on it is there two sensors with plugs on the throttle i only saw one plug on the pedal
holy crap, i'd take that in, something unrelated to the exhaust is causing them. That is all I can tell you from the info given. You haven't messed with that stuff in anyway?
and the culprit is which for those of you that dont know is located here now how would i go about fixing this for one there is no chance of even getting anything bigger than my hand in there and the gm service manual emphasises <--(sp?) that when doing a wiring repair the wire must remain the same length
think tank time whatta ya got
I see now I was in limp mode in my head . All I can think of is have someone with smaller hands then you get back there and do it. Or did you try getting the wire out threw the other side?
tried that too its connected to another harness and clipped to the car in about 50 places
gonna try one of these tommorow Posi-Tite- Watertite Connector will let you all know how that goes
cant get the crimpers in there however i did manage to get the wires stripped had to pull one through to the inside of the car but i got both ends stripped and im gonna use that twist lock connector on it shouldnt be too hard since i can get my hand in there
breds2k
19
09-21-2015 10:24 AM
