Help- Car Wont Turn Over
Went to get in my car this morning and it wouldnt turn over! Waited a few hours and had my buddy try and boost me, nothing...a light in the dash with a lock comes on, but still cant turn over. I assume its something to do with the battery saver, can anyone shed some light on getting past this to boost the vehicle so I dont have to get my car towed in??
Kinda dont want to be hassled about the trunk mount meth kit and my aftermarket 60lb injectors and custom tune. I still have some warranty left on the vehicle and dont want to have to remove my meth kit before the tow?
when i say locked steering wheel i mean like after the car is off by accident you turn the wheel while getting out and it locks... if its locked the car will not start and you have to move the steering wheel to loosen it to start it...
I will definatly try that when i go home! going to try to remove the battery and charge it up and then try, maybe a relay or something is gone?? worked great a few days ago when i last started it
nope its stock
Last edited by QuikSilverSS; May 2, 2008 at 03:13 PM. Reason: Automerged Doublepost
the lock symbol looking thing on the dash is the light for the factory security system. the car is equipped with passlock3. which means that when you put the key in the ignition and turn it, it sends a encripted code to the bcm or pcm and the conputer has to reconize it to start the vehicle. my best bet is something isnt seeing the correct or matching code causing the car not to start or turn over
Also would this still cause no power to
the power locks? when I got out of the car I had to manually lock the doors
i had the passlock problem for a hella long time in my 2.4 grand am, got in fixed once, and it then if facked up again...really a shitty deal, but since its electrical it should be covered by warranty right
either the key or the securiity module went bad, now that you have tried to start it 3 times with what it thinks is an invalid key, the pcm gets locked out by the security module, needs to get towed to the dealer.
would removing the battery all togather help and then reinstall?
I am pretty sure that I didnt leave any accesories running when i got out of the car??
Does this seem like a symptom of a passkey problem?
I am kinda hoping that its a dead battery and something i dont need to bring in for warranty seeing how I have a custom tune and aftermarket injectors, not to mention the big honking methanol injection kit in my trunk!
Getaway_Driver
40
Sep 10, 2015 09:11 AM
Getaway_Driver
Sep 8, 2015 09:41 AM
