HELP: Headlight Problem!
Old May 29, 2007 | 05:34 AM
REIGN SS's Avatar
Original Hayden Fanatic
Question HELP: Headlight Problem!
Im having a curious problem with my driver side head light.
Both headlights comes on when i unlock my doors like normal, but when i start my car the driver side headlight turns off. Brights still work, and if i shut the car off lock it up, and unlock it the light works again till i start the car...Then boom off again?!? Replaced it with a stock bulb and everything works even when i start the car...
I just find it weird that the bulb works w/ the courtesy lights, and the brights work even if the car is running, but the bulb shuts off as soon as i start the car.
They are aftermarket bulbs, i don't know what kind for sure i got the from a friend...
Old May 29, 2007 | 08:57 AM
RaineMan's Avatar
Hmm... so everything works fine with the stocker bulbs in?
Old May 29, 2007 | 01:39 PM
Coblasts's Avatar
The first situation I think the bcm turns the lights on .
Its sound weird though ,do a ohm check between the after market bulb and the stock one to see what the difference is.This could have something to do with it.
Are you sure you have the right after market bulbs for our car.
Old May 29, 2007 | 03:13 PM
fr33k's Avatar
Could they be a brighter/more wattage bulb? The BCM or the Headlamp relays might see too much amerage goin through it and the relay kicks off.
edit: Have you swapped your left from your right to see if the problem is in the right side after the swap. If so, that might eliminate wiring and stuff.
Old May 29, 2007 | 08:10 PM
REIGN SS's Avatar
Yep 9007, ive been using them for about 6 weeks now
Yes
No I realized it was out at 4:30 in the morning, after working all night so i just but one of the stockers back in...
Old May 30, 2007 | 06:06 PM
cashstacker's Avatar
The headlight that dosnt work is burnt out. I had this happen to me except it was a little different. When you unlock your car and the lights come on those are your brights. So when it happened to me id unlock my car and only one would light up, but when id start my car both would light up. I threw out those headlights and went and got some new ones and now they work again.
Old May 30, 2007 | 06:10 PM
an0malous's Avatar
^^ yup hes right.
the lights for unlock are your brights. thats whats confusing you.
having projectors makes this glaringly obvious because they are separate bulbs, but with a single bulb/double filament its not so evident.
your low beam filament is gone in one of the bulbs.
Old May 30, 2007 | 06:15 PM
2.4SlowassBalt's Avatar
you low beam filament is blown same thing happened to me, you gonna have to replace the light bulb, reason that they work when you unlock with the key is because they use high beams for that.
Originally Posted by an0malous
^^ yup hes right.
lol both of you beat me to it.
Last edited by 2.4SlowassBalt; May 30, 2007 at 06:15 PM. Reason: Automerged Doublepost
Old May 30, 2007 | 08:29 PM
REIGN SS's Avatar
I might have a short somewhere, bc the stock bulb blew last night
Old May 30, 2007 | 09:52 PM
Coblasts's Avatar
Dont touch them with your fingers
You know you can't touch them with your fingers.The oil from your fingers creates a hot spot and causes them to blow prematurely.
Old May 30, 2007 | 10:02 PM
HackAbuse's Avatar
When you use the unlock feature, the headlights use the brights. So your low beam coil probably blew
Old May 30, 2007 | 10:22 PM
REIGN SS's Avatar
yes
turbochargedss2012
Sep 20, 2023 12:17 PM
yellow dragon
Sep 28, 2015 09:49 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
