Help i have these codes
Old Feb 8, 2008 | 02:08 PM
Coblt ss super's Avatar
P0036
P0138
P0172
P0300
Do these have anything to do with the O2 sensor on the dp? let me know guys, i cleared them with the interceptor but i wanna know what they are
Old Feb 8, 2008 | 02:10 PM
D4u2s0t's Avatar
p0172 is rich, p0300 is random misfire, don't know the others off the top of my head.
Old Feb 8, 2008 | 02:38 PM
ok the rich one i can understand since im tuned for a 2.6 pulley but i got a 2.8 on it
Last edited by Coblt ss super; Feb 8, 2008 at 02:38 PM. Reason: Automerged Doublepost
Old Feb 8, 2008 | 02:39 PM
REIGN SS's Avatar
Original Hayden Fanatic
P0036 is the 2nd 02 sensor
Old Feb 8, 2008 | 06:06 PM
ok i knew that one was gunna go, i pulled the wires outta the harness on the o2 sensor and didnt know which way they went back in do you have a pic of how the wires go in?
Old Feb 9, 2008 | 12:44 PM
what is P0138?
i keep throwing
P0300
P0036
and i have to keep clearing them
Old Feb 9, 2008 | 12:59 PM
ssmokin's Avatar
P0138 HO2S Circuit High Voltage Sensor 2 ECM, PCM
https://www.cobaltss.net/forums/problems-service-maintenance-69/cobalt-dtc-thread-merged-12015/
Old Feb 9, 2008 | 01:05 PM
alright what does that mean? What could have caused that
Old Feb 9, 2008 | 01:09 PM
ssmokin's Avatar
it also has to do with the 2nd O2 sensor...
Old Feb 9, 2008 | 01:10 PM
ok i knew it would throw that, i ripped the wires out of the sensor connection on the rear tranny mount and dont know how they go back into the harness.
Old Feb 9, 2008 | 01:13 PM
Psykostevo's Avatar
Usually throws that code when the sensor is not connected to the car. you need to have the sensor disabled.
Your misfire code is something to worry about. Go get tuned properly.
Old Feb 9, 2008 | 01:15 PM
i am tuned properly, i never threw that code ever, just now since the O2 sensor is messed up
Old Feb 9, 2008 | 01:30 PM
RedEcotecSS's Avatar
check to make sure the wires on your rear o2 arent touching metal. then check the fuse in your fuse panel under your hood called "EXH". if ur o2 wires are touching metal, it'll blow that fuse. make sure they didnt accidently get cut or aanything. (they wont have to be completely seperated to be cut and touching metal.)
Old Feb 9, 2008 | 01:40 PM
Psykostevo's Avatar
you are not properly tuned if your rear O2 is not disabled. hence all of your codes. See what I mean? Now your car thinks it's rich because of voltage issues, but in reality it might not be. Your shortband AFRs are going to be out of whack.
turbochargedss2012
Sep 20, 2023 12:17 PM
ernnyyes
Oct 2, 2015 05:16 PM
Extremespeed
Sep 29, 2015 04:34 AM
DocSvensk
Sep 27, 2015 02:24 PM
OrangeCoba
Sep 25, 2015 06:06 PM
