HELP!! lights aren't workin
Old Dec 19, 2009 | 10:53 PM
bruiserinpink's Avatar
Exclamation HELP!! lights aren't workin
So, i tried searching and no real problem was discovered with this, but i noticed last night while driving on i-10 that my dash lights weren't working, so we looked at all the fuses and everything seemed okay, and so when i was out driving tonight, someone stopped me and told me that my tail lights aren't working, i have tried everything i can think of. Has anyone else had this problem and fixed it?! please let me know!!!
Old Dec 20, 2009 | 12:33 AM
dayhoff35's Avatar
i had it happen to me my tail light fuse was blown
its the parking lamps fuse i think change that nad you should be fine
its in the fuse box under the hood but i forget what fuse nember
Old Dec 20, 2009 | 12:49 AM
kafer79's Avatar
Did you check both fuse boxes? One is in the engine compartment on the driver's side, the other is in the center console on the passenger's side?
Old Dec 21, 2009 | 02:16 PM
yeah i checked them both, i'll go ahead and double check them!
Old Dec 21, 2009 | 04:54 PM
Coblasts's Avatar
Sound like your light sensor on the dash isnt working.The fuse for the taillight has nothing to do with the dash lights.
This controls your tail lights and dash lights.(when lights are on Auto)
Try manually turning on your lights .Do your tail lights come on now?????
If so it is he sensor.
Old Dec 21, 2009 | 05:17 PM
DaBuzzard's Avatar
It DOES as a matter of fact. The cluster light circuit is fed from AFTER the park lamp fuse, this is done so that if the park lamp fuse blows your cluster goes out too. You can't see the back of your car from inside but you can see the cluster, this lets you know there is a problem before someone runs you over in the dark.
Fuse is labeled PRK LMPS, under hood fuse box. 15 amp iirc.
Old Dec 21, 2009 | 10:30 PM
thanks so much for helping me out with the fuse lable, i got it all figured out, turns out the fuse tap that i had to use for the LED's in my projectors just needed to be changed!! thanks for all you guys' help!!
Old Dec 22, 2009 | 06:50 PM
Coblasts's Avatar
Thanks for the correction,Looked at the prints a few times and never realized the cluster lights are feed from that fuse through the BCM.
RaginChopsuey
Oct 27, 2015 01:27 PM
brandon04
Oct 21, 2015 07:04 AM
dennis69
Oct 20, 2015 04:49 PM
z28addiction
Sep 28, 2015 12:03 AM
