help noob with brakes
Old Apr 5, 2012 | 08:26 PM
breds2k's Avatar
hey guys just did my front brakes, replaced discs and pads like normal. Did everything the way ive done brakes before.
Put everything back together went for a drive, pedal goes to the floor, brake fluid is right at the top and nothing is leaking and I didnt disconnect anything to need the brakes to be bled. So what did I do wrong?
edit: car stops but i wouldnt trust it in traffic, the pedal touches the floor.
Old Apr 5, 2012 | 08:56 PM
ItalianJoe1's Avatar
You have a hydraulic issue, had to get air in the system somehow or your master is bad. Did you bleed the brakes?
Old Apr 5, 2012 | 08:58 PM
breds2k's Avatar
no, i did not bleed the brakes.
Old Apr 5, 2012 | 08:59 PM
Try that first. If it helps some, you have air somewhere. If not, then your master cyl is shot.
I'm guessing the brakes were working normally before you changed the pads/rotors?
Old Apr 5, 2012 | 09:06 PM
breds2k's Avatar
yes just pretty worn.
Old Apr 5, 2012 | 11:41 PM
bluebalt07's Avatar
I agree with joe. When you compressed the caliper air must've got in the lines somehow. Did you take the cap off the master when you compressed the caliper?
Old Apr 5, 2012 | 11:49 PM
breds2k's Avatar
No i didnt. And there is the problem.
There was "oil" all over the garage floor, right on the axle boot. I was thinking some how when i jacked the car up or something crazy the axle boot ripped but thought there was no way possible that it could happen. Plus it wasnt grease it was oily substance.
Then i realized that brake res in directly above that, so it must have overflowed and backed up. Does that sound right?
Old Apr 5, 2012 | 11:59 PM
bluebalt07's Avatar
I believe there is an over flow hole on the reservoir so that may be your issue. I can't remember though if that is an open hole or whether it has a valve or something on the inside. I'd definitely try filling the reservoir and bleeding the brakes before anything else. But for future reference on any vehicle, take the cap off first and that way you don't build up extra pressure in the master when you compress the caliper.
Jan 12, 2016 12:01 AM
biniecki
Oct 25, 2015 02:23 PM
Sep 27, 2015 08:53 PM
