Help with P0068 - ENG PWR REDUCED
Under heavy acceleration in 1st or 2nd my '05 2.0l 'balt SS/SC will suddenly enter limp mode (ENG PWR REDUCED) with a CEL code P0068- Throttle position and engine load do not agree: the ECM detected that the TPS value and engine load do not agree with the expected TPS value and engine load.
It happens pretty much randomly - the car will run fine for weeks at a time then out of the blue this will happen.
If I turn the engine off for about 5 minutes, I can run the car with the CEL on fine as long as I'm easy on the accelerator. If I leave the car overnight, the CEL will disappear and I can usually drive it fine but it's a crapshoot when the same problem will happen again.
I've taken it into the shop a number of times and they're pretty much at a loss.
The car has a K&N CAI on it from the previous owner. I've already cleaned the MAF sensor.
Any ideas? I'm considering replacing the K&N with a stock intake but not sure if that will help.
Is the procedure for cleaning these the same as for cleaning the MAF sensor?
The BARO and SCIP share the same harness at the neck of the supercharger. The BARO floats above the oil filter and the SCIP is the first sensor you see on the top of the supercharger. They are very clost to each other. The SCIP is held in with one bolt, pull it out and check the gasket to see if its damaged, cracked or dried out. The BARO is held in place with a bracket with 2 bolts, check to see if the nipple of the sensor is free and clear. They can be cleaned with sensor cleaner, like you would use to clean your MAF. To test them use a scan tool to compare the readings; the BARO and the SCIP should read almost the same when the engine is not running.
Extreme Dimensions
Jun 29, 2016 11:01 AM
