Help please!!!
Help please!!!
So I just launched my car in first and then went into second and I lost 1st,3rd, and 5th gear Im thinking its the linkage because I can use 2nd 4th and reverse. I need quick advice and where I need to look. Sorry for being a Noob but this has never happened to me :/
problem is this is a know issue with all balts, fix is a bolt and a teflon lock nut on the end. easy fix, but say you do it your self, then your also fugded because if the dealer see you worked on it then they knwo you could have fudged somthing up causing the mfg waranty to fufill and not be valid any longer
