Help please!!!
Old Sep 19, 2010 | 08:52 PM
Sbrtrg's Avatar
Help please!!!
So I just launched my car in first and then went into second and I lost 1st,3rd, and 5th gear Im thinking its the linkage because I can use 2nd 4th and reverse. I need quick advice and where I need to look. Sorry for being a Noob but this has never happened to me :/
Old Sep 19, 2010 | 08:55 PM
Chevycobaltss3's Avatar
Tension pin the linkage pin that connects the linkage to the transmission it's under the fjuse box outside in the engine bay
Old Sep 19, 2010 | 09:58 PM
Sbrtrg's Avatar
So I need to take off the fuse box? and just buy a new pin and install it?
Old Sep 19, 2010 | 10:14 PM
Wut u would do is take It to the dealer an if u can't then that should be your fix so yes fuse box off
Old Sep 19, 2010 | 10:15 PM
TommyP's Avatar
AWD > FWD
I would try to fix it yourself first, they might mark it as abuse and F your warranty. You know dealers.
Old Sep 19, 2010 | 10:17 PM
Sbrtrg's Avatar
no doubt
Old Sep 20, 2010 | 06:33 AM
problem is this is a know issue with all balts, fix is a bolt and a teflon lock nut on the end. easy fix, but say you do it your self, then your also fugded because if the dealer see you worked on it then they knwo you could have fudged somthing up causing the mfg waranty to fufill and not be valid any longer
