Help please, i messed something up
I was putting in a wide-band gauge and i cant get my motor to turn. The radio come on and everything but the motor will not turn. The gauge cluster says power steering and i have no idea what i did. Any help would be appreciated.
here, its a pretty cheap fix
http://kalecoauto.com/index.php?main...products_id=10
Or splice into any...
Is the light with car and lock illuminating? That happened to me once before. Went to start the car and it wouldn't do anything. I just pressed unlock on the key fob a few times and it started right up.
i think it is but im not 100% on that. if anyone can through me a cell number ill send a pic message alot quicker than getting the pictures up on here
You have checked the I/P IGN fuse under the hood it 20 amps.
Also what color where the wires you tapped into for the wideband,
And if you didnt how did it hook into the electrical system,
Please explain
Please explain
alright let me see what it is and ill get back on
the wire was red with a white strip i was already sliced into it it before for another gauge but i took it out
Last edited by Bigmacss/sc; Feb 7, 2010 at 11:36 AM. Reason: Automerged Doublepost
