Help please, i messed something up
Old Feb 6, 2010 | 03:15 PM
Bigmacss/sc's Avatar
I was putting in a wide-band gauge and i cant get my motor to turn. The radio come on and everything but the motor will not turn. The gauge cluster says power steering and i have no idea what i did. Any help would be appreciated.
Old Feb 6, 2010 | 03:19 PM
NWAE Cobalt's Avatar
you either cut your battery cable or your muffler bearings are shot...
Old Feb 6, 2010 | 03:20 PM
Fonzi1289's Avatar
Does it make any noises?
Like clicks or anything?
Old Feb 6, 2010 | 03:22 PM
here, its a pretty cheap fix
http://kalecoauto.com/index.php?main...products_id=10
Old Feb 6, 2010 | 03:26 PM
YelloEye's Avatar
Uh....how...I cant even begin to think of how you did this....tell me you didnt cut into an ECU wire.....
Or splice into any...
Old Feb 6, 2010 | 03:32 PM
no, i did not splice or cut anything. no, i cant her anything clicking
Old Feb 6, 2010 | 03:33 PM
EatonTVS07's Avatar
Ddi you check your fuses?
Old Feb 6, 2010 | 03:35 PM
exiged's Avatar
x2 sounds like you blew one.
Old Feb 6, 2010 | 03:37 PM
yea i checked the fuses.
i am getting a fuse tester and im gonna test every fuse
Last edited by Bigmacss/sc; Feb 6, 2010 at 03:37 PM. Reason: Automerged Doublepost
Old Feb 6, 2010 | 03:38 PM
Fonzi1289's Avatar
How did u install the wideband then?
That cause this to happen?
Old Feb 6, 2010 | 03:44 PM
i havnt got the o2 gauge put in yet, i was just running the wire, i put one for a ground and thats about it
Old Feb 6, 2010 | 03:48 PM
exiged's Avatar
i think pics would help of what EXACTLY you did to ANY wiring
Old Feb 6, 2010 | 03:49 PM
EatonTVS07's Avatar
X2 pics would help.
Old Feb 6, 2010 | 03:50 PM
alright, i have to go back to my car and ill get some pics
Old Feb 7, 2010 | 10:11 AM
ill get pics up in in a few, i have wicked helping me out a little bit right now. i think its the theft system
Old Feb 7, 2010 | 10:13 AM
EatonTVS07's Avatar
Is the light with car and lock illuminating? That happened to me once before. Went to start the car and it wouldn't do anything. I just pressed unlock on the key fob a few times and it started right up.
Old Feb 7, 2010 | 10:17 AM
i think it is but im not 100% on that. if anyone can through me a cell number ill send a pic message alot quicker than getting the pictures up on here
Old Feb 7, 2010 | 10:25 AM
Mindrot's Avatar
Security? Unhook the battery and let everything reset? Maybe you drained the battery?
Old Feb 7, 2010 | 10:26 AM
Fonzi1289's Avatar
YEah that happened to me to.. Just watch ur speddometer area and see if it blinks at all
Old Feb 7, 2010 | 10:27 AM
i already tried that, i even went and got my battery charged up and everything. still the same thing when i put the battery back in
my speedo doesnt work or my gas gauge either
Old Feb 7, 2010 | 10:30 AM
Mindrot's Avatar
Unfortunately that's all I got. We're going to have to see pictures. Post them up here for everyone to see
Old Feb 7, 2010 | 10:31 AM
ill get to it soon, i need to get back to my car
Old Feb 7, 2010 | 10:41 AM
Fonzi1289's Avatar
Sounds like ur ignition isnt even turning on..
Old Feb 7, 2010 | 10:47 AM
Coblasts's Avatar
You have checked the I/P IGN fuse under the hood it 20 amps.
Also what color where the wires you tapped into for the wideband,
And if you didnt how did it hook into the electrical system,
Please explain
Old Feb 7, 2010 | 11:32 AM
alright let me see what it is and ill get back on
the wire was red with a white strip i was already sliced into it it before for another gauge but i took it out
Last edited by Bigmacss/sc; Feb 7, 2010 at 11:36 AM. Reason: Automerged Doublepost
