Help pls 05 cobalt ls
Old Feb 9, 2025 | 10:36 AM
Cobaaltdude's Avatar
I have a 05 cobalt and my fuel pump cuts out to early, I also have a 07 with a good fuel pump but the connector on the 05 is 2 plugs on pump on the 07 it's 1 plug am I able to take the wiring and use it on the 05 from the 07 when I look up wiring diagram it shows its the same plug ect am I able to convert that over ? Ok I'm gonna have to switch charcoal filter if so bc the fuel pressure sensor is on the pump ,on the 07 it's on charcoal filter
Old Feb 9, 2025 | 11:21 AM
Ok I probably should have started here I bought a 05 cobalt it runs good but has a random misfire when u stop at red lights it would stall out ,the other day it died going down freeway I fixed all codes with my parts cobalt and seemed like it fixed it I had the issue of my fuel filter leaking out the single port side had it locked in no leaks and out of nowhere starts leaking again I feel like the fuel pump is not keeping consistent pressure ,any help would b appreciated
Old Feb 28, 2025 | 10:26 AM
The issue was really the crankshaft position sensor losing connection after it heated up
rauq
Jan 17, 2024 08:52 AM
Delta coupe
Jul 14, 2011 12:22 AM
scottyguy401
Mar 16, 2010 01:14 AM
