HELP supercharger very hot!!
Old Oct 20, 2006 | 12:44 PM
2fastforyouraSS's Avatar
my car is not running right its running around 214 then the thermostat finally kicks in and brings it down, but i wasnt getting but 15lbs of boost when it was hot, i usally get 18!!! The car seems much slower.. what could be the problem??
Old Oct 20, 2006 | 12:45 PM
Drakonen2000's Avatar
maybee it bleeds boost when it gets hot...idk. could be a sensor, thermostat, coolant levels, blockage in the lines...all kinds of things.
Old Oct 20, 2006 | 12:52 PM
i just got my spark plugs gapped and this started happening i dunno if this is the problem but they're gapped at .40 stock plugs and im running stage 2, 2.8 pulley, and injen intake. is that about right??
Old Oct 20, 2006 | 12:54 PM
CobaltSS422's Avatar
mine stays around 180 when i'm driving and it climbs when i'm sitting in traffic. it has gotten that high but only when the car is sitting. 18psi with the PB 2.8? That does make sense. I have a 2.7 and get between 17-18 and when i slap my 2.5 i'm between 20-21psi.. I dunno.. maybe because i have an exhaust and less backpressure
Old Oct 20, 2006 | 12:56 PM
im satisfied with my boost i dunno how but i do get between 17 and 18lbs.. its whining like crazy but im not really going anywhere!! i dont get it it seems like it should be faster, its like it stutters soon as i downshift like the throttle response isnt right or something
Old Oct 20, 2006 | 12:58 PM
06blackg85ss's Avatar
regap plugs to .35 and get a step colder.... also... s/c gets hot when producing that much boost... and once your IAT2 temps get above a certain temp car starts pulling timing and whatnot...
Old Oct 20, 2006 | 01:01 PM
so maybe invest in some NGK Bkr's and heat exchanger?? I dunno what to get everything is failing on me right when im out of money.. My tires are bald as hell and my clutch is going
Old Oct 20, 2006 | 01:28 PM
maybe you should take it easier on you car man.... Ive had mine for over 13000 miles now... much more heavily modded than yours (should be close to 300whp next dyno)... my tires look brand new and my stock clutch still holds as good as the day I brought it home...
Old Oct 20, 2006 | 01:36 PM
NightriderCobaltSS's Avatar
Here is the reason why
see the 60 , 80 and 90 % when you reach those threshold you boost is limited to those figures from max boost.
Old Oct 20, 2006 | 02:35 PM
i have no clue how to read that.. can u just explain what i need to do, or what not to do.. thanks Jake
Old Oct 20, 2006 | 02:44 PM
1. Find someone with HP tuners and they could set all those values to 100% so you would get full boots despite IAT ,ETC , or COT.
OR
2. Find a away to bring IATs down. so the compter wont limit your boost.
ect boost... limited to your ECT (engine coolant temp) when that get to 212deg it pulls boost to 60%
IAT2 gets above 207 deg pulls boost...
GaryGibblez
Jan 14, 2020 10:35 AM
Sean Cummings
Jan 8, 2020 10:17 AM
RaginChopsuey
Oct 27, 2015 01:27 PM
brandon04
Oct 21, 2015 07:04 AM
z28addiction
Sep 28, 2015 12:03 AM
