hid fog lights flicker. what the hey??
Old Apr 8, 2010 | 04:45 PM
ecot3c inside's Avatar
so while I was switching out my stock headlight assemblies to some halo projectors I decided to throw some hids on the fogs. brand is xentec (if it even matters), direct plug and play. epoxied and secured the ballasts to the bottom of the headlight brackets tested everything out, worked good...(with the engine off), but recently it seems as though it get some sort of disturbance from the engine?? it flickers, I was certain I did everything 100% correct. the flickering isn't horrible, but noticeable. My ballast are placed in the same spot most cobalt owners have theirs.. any thoughts or did this happen to you?
Old Apr 8, 2010 | 04:49 PM
rossshady120's Avatar
i have the same problem my audio guys said there not enough power and i need to upgrade my batt. I have pioneer 4100 with a nasty kicker amp and two 12" mmatts subs. its pretty cool when they start to strobe its like your pulling someone over or something and you dont even know it lol
Old Apr 8, 2010 | 05:13 PM
I don't have a giant strain on my battery though, my audio system is stock.
Old Apr 8, 2010 | 08:55 PM
TommyP's Avatar
AWD > FWD
did you try a relay harness? That way you get power directly from the fuse box terminal.
Old Apr 9, 2010 | 12:06 AM
no I will look into that, but It shouldn't be a problem because the fogs are not attached to the drl.
dennis69
Oct 20, 2015 04:49 PM
riceburner
Oct 2, 2015 05:47 PM
MrInsanityWolf
Sep 29, 2015 04:54 PM
Slick_Nick
Sep 28, 2015 09:15 PM
