HID problem help please
ok so i recently got the ddm 8000k hid kit and everything was included like it should but anyways i got the ballasts and wires run to the headlights but i have no clue how to get power to the headlights, im running a positve wire from the fuse box and a ground from a bolt by the drivers side fender but still nothing lights up, just the parking lights
if anyone could inform me on this that would be
if anyone could inform me on this that would be what exactly do you mean by wiring fail? like what i did by running the wire to the fuse box or what
what I mean was if you spliced into the wiring and added a wire to run for each then ya failed. But if your harness had a wire made to be run to the fuse box then your fine. How about you post up a pic of what you're working with and we can tell you for sure. Everyone knows we here at CSS.net love pics.
I just put 10ks in my headlights and fogs and first tried to use the relay and that didn't work so i just didn't use it, did the plug and play feature and pulled the drl fuse and it worked like a charm. Ya post a pic man cauz i wanted mine to look super blue and they look really white so im anxious to see what you 8ks look like.
