HID problem help please
Old Apr 14, 2010 | 10:10 PM
Midwest Ecotecs's Avatar
Angry HID problem help please
ok so i recently got the ddm 8000k hid kit and everything was included like it should but anyways i got the ballasts and wires run to the headlights but i have no clue how to get power to the headlights, im running a positve wire from the fuse box and a ground from a bolt by the drivers side fender but still nothing lights up, just the parking lights if anyone could inform me on this that would be
Old Apr 14, 2010 | 10:12 PM
BLAZIN07SS's Avatar
I'm too JDM for you
you got the 9007 kit correct? and are you using a relay harness or just a plug and play kit?
Old Apr 14, 2010 | 10:13 PM
TommyP's Avatar
AWD > FWD
If he's got a wire run to the fuse box and one to the strut bolt he has to be using a relay. That or this is the biggest HID kit wiring fail of all time.
Old Apr 14, 2010 | 10:24 PM
yes it is the 9007 kit and it is said to be plug and play but im not sure on the relay
what exactly do you mean by wiring fail? like what i did by running the wire to the fuse box or what
Old Apr 14, 2010 | 10:25 PM
JPizzle's Avatar
The headlights have to know when to turn on... So that is the wire that you are missing right now.
BLAZIN07SS's Avatar
I'm too JDM for you
okay then all you should have to do is plug the blue 9007 connectors together
Old Apr 14, 2010 | 10:27 PM
TommyP's Avatar
AWD > FWD
what I mean was if you spliced into the wiring and added a wire to run for each then ya failed. But if your harness had a wire made to be run to the fuse box then your fine. How about you post up a pic of what you're working with and we can tell you for sure. Everyone knows we here at CSS.net love pics.
Old Apr 14, 2010 | 10:30 PM
JPizzle's Avatar
Yea. A picture would be best.....
Old Apr 14, 2010 | 10:43 PM
thats it?
ill try and get some up tomorrow
Old Apr 20, 2010 | 02:11 AM
Snake34's Avatar
I just put 10ks in my headlights and fogs and first tried to use the relay and that didn't work so i just didn't use it, did the plug and play feature and pulled the drl fuse and it worked like a charm. Ya post a pic man cauz i wanted mine to look super blue and they look really white so im anxious to see what you 8ks look like.
turbochargedss2012
Sep 20, 2023 12:17 PM
yellow dragon
Sep 28, 2015 09:49 PM
Iceberg
Sep 28, 2015 01:31 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
