Hole in firewall!
Old Sep 4, 2010 | 12:52 PM
  #201
ChevyRockstar's Avatar
Originally Posted by WSFrazier
Sounds like your transmission shop can't even install a decal, let alone a clutch.
This^ not the cars fault, poor installtion = shitty feeling clutch
Old Sep 4, 2010 | 01:27 PM
  #202
alleycat58's Avatar
Yeah. Call that shop and give them hell, sounds like they don't have a clue what they're doing.
Old Sep 4, 2010 | 01:32 PM
  #203
N1ckateen's Avatar
i called, but they're closed til tues. i had my brother in law push on the clutch and i looked at the hose coming through the firewall and it flexes quite a bit when the clutch is pressed.
Old Sep 4, 2010 | 01:34 PM
  #204
N1ckateen's Avatar
frazier, may i ask. Did you used to drive the cobalt with your eyes closed?
Old Sep 4, 2010 | 01:46 PM
  #205
alleycat58's Avatar
If you have someone that can help, you can bleed the clutch yourself - pretty sure there's a how-to on this site. Given the symptoms you've described, I think a simple bleed should fix all your problems. If by chance it doesn't, it means they botched the install and either didn't align something right or didn't tighten something right.
Old Sep 4, 2010 | 01:49 PM
  #206
alleycat58's Avatar
Here https://www.cobaltss.net/forums/how-...system-164547/
  #207
N1ckateen's Avatar
ok well i guess me and my brother in law will throw it up on the jack and take the wheels off and bleed all the lines and throw some new dot 3 in and see what happens? i need to do the brakes too i'm assuming since it's all on the same res. right? or can i do just the clutch
Old Sep 4, 2010 | 01:51 PM
  #208
alleycat58's Avatar
No you need to do the whole system IIRC. Look at that how-to I posted but read the whole thread, there are some corrections/clarifications later in the posts.
Old Sep 4, 2010 | 01:54 PM
  #209
N1ckateen's Avatar
can u post the link up so i don't have to search it please?
Old Sep 4, 2010 | 01:56 PM
  #210
USMCFieldMP's Avatar
Rattlesnake Race Shop
Originally Posted by N1ckateen
The clutch won't even push in unless i use a great amount of force, then i hear air depress and the clutch finally goes all the way in. but when i start the car in neutral even if the clutch is pressed in i can't put it into any of the gears and if i start the car with it in a gear weather the clutch is pressed in or not the car just starts moving instantly and then i can't shift into any other gears so i have to drive it in the gear i start it in. i drove all the way home in first going like 8 mph from work last night just so i wouldn't have to pay a tow bill on top of all the other **** i've had to pay for in the past few days.
Did you even read my post???
Installer Error. The clutch needs bled. Hell, I even offered to come help.
This.
This as well. All valid points.
She already posted it...........
Last edited by USMCFieldMP; Sep 4, 2010 at 01:56 PM. Reason: Automerged Doublepost
Old Sep 4, 2010 | 01:58 PM
  #211
N1ckateen's Avatar
ha if u want, but i can't afford your demands as i'm broke as **** right now haha
my bad. i see it now
Old Sep 4, 2010 | 02:15 PM
  #212
N1ckateen's Avatar
ok my bro in law is on his way over with the tools and ramps to get the front end up. time to dedicate another saturday to the cursebalt and get it back on the road once again! I am determined...
Old Sep 4, 2010 | 03:38 PM
  #213
N1ckateen's Avatar
ok we blead all the lines topped blead topped blead over and over. tightened it all back up and got the same results. slave?
Old Sep 4, 2010 | 03:59 PM
  #214
It could be the Master Cylinder. They do go bad. There is a new one for sale right now on GM Sport Compact . Net.
The throw-out bearing should have been replaced when they replaced the transmission.
The only other thing it could be, is an improper installation of the clutch.
Old Sep 4, 2010 | 04:41 PM
  #215
alleycat58's Avatar
I'm gonna go with improper installation myself. Just given the fact that they couldn't get the GMPP to fit and all that jazz, they don't really sound like they know what they're doing.
Old Sep 4, 2010 | 04:46 PM
  #216
bobbyhill31286's Avatar
keeps on gettin worst for ya...sorry bout ur luck man
Old Sep 4, 2010 | 04:47 PM
  #217
N1ckateen's Avatar
well damn i guess it's pretty obvious i'm not irish huh
Old Sep 4, 2010 | 04:54 PM
  #218
no pots of gold or rainbows or 4 leafed clovers or any of that **** huh
i gonna say u should get rid of that busted ass car
Old Sep 4, 2010 | 04:57 PM
  #219
N1ckateen's Avatar
tbh the only problem i have had with the car the entire time is clutch. nothing else has had any problems whatsoever. other than the boost gauge doesn't work, but hell the entire apillar looks like hell. homeade tripod with a light on it that does nothing and 2 empty holes for the other 2 gauges. guess we're removin the master now.
Old Sep 4, 2010 | 05:06 PM
  #220
WSFrazier's Avatar
Hana. That was my old pillar pod. The light was for the meth kit. I had an after market boost gauge. Probably why the oem one dont work. Also had a wideband and interceptor in the other 2 holes. Reason it looks home made is because the plx wideband wouldn't fit.
Old Sep 5, 2010 | 12:32 AM
  #221
N1ckateen's Avatar
it still has the blue aftermarket cobalt gauge, but it doesn't work.... why is the apillar being heald on with a screw? also the interior rattles like you had a beaten ass system in it.
Old Sep 5, 2010 | 03:46 AM
  #222
The A-Pillar is held on with a screw... because that's how aftermarket A-Pillars are held on.
If you want one that is nice, and looks like stock so that you can hide the screw, order the ZZP A-pillar. $80, I think. Might be $85. Looks identical to stock, only with 2 extra holes.
Your interior rattles like that because of the solid motor mount and possibly solid Transmission mounts. They'll make sure you aren't destroying other things though... like axles and transmissions from Wheel Hop.
And if the Boost Gauge is an Electronic one, which I'm guessing it is, you'll probably have to order the rest of the harness and parts... unless they are lying in the engine bay somewhere. Does it even light up? The wiring harness should shoot through the firewall... find it and follow it... you might find the MAP sensor that came with it. If there is no harness... you'll need to call Auto Meter... or just order a new one on eBay. If that's the route you go... search eBay for "ihavethebestpriceperformance"... they have the best pricing on Auto Meter that I have found. Just get a MECHANICAL Boost Gauge. It'll only be $50-$80, depending on which model you get.
The ones you see in my Sig (which look pimp, I think...) are the Auto Meter ES Series.
Old Sep 5, 2010 | 08:33 AM
  #223
WSFrazier's Avatar
Yes, the blue Autometer Cobalt boost gauge was electronic. Car was wrapping the stock boost gauge since it saw over 20psi. Needed something that went higher.
From the pics of your engine bay, it looks like it's missing the sending unit that attaches to a vacuum line. Not sure why the PLX Wideband and the AeroForce interceptor gauges are missing, either.
The car vibrates like that because you have the BWoody solid motor and trans mounts, not because of some "system". ROFL, le sigh.... fkn children...
Whoever tried returning the car to stock, did a **** poor job of it.
This is what your missing for the boost gauge:
Old Sep 5, 2010 | 11:49 AM
  #224
N1ckateen's Avatar
anything else you can think of about the car that i may not know? i'm just trying to learn the history of the car and try to figure out what is still there and what isn't still there.... when i got to the dealership there was a cheap ass shitty oil pressure gauge in there, wasn't connected to anything. i just took it out and threw it away because it was wrattling really bad and it was annoying as hell.
would the stock boost gauge work if i put one back in there?
Old Sep 5, 2010 | 11:54 AM
  #225
csementuh's Avatar
The stock boost gauge should work as it is an electrical gauge. So long as the harness behind the pillar wasn't cut out or something. I have a stock pillar and boost gauge for sale if you need one.
