Hood release not work, need help.
then chances are the cable is either stretched or it broke somewhere down the line, what you can try is go underneath the vehicle look up, you'll be able to see the hood release latch as well as the cable attached to the latch. take a pair of pliers and pull on it, that should release the hood
did it make a sound when you pulled the lever at all? did you try pulling up on the hood decently hard to see if it was just stuck? If the cables broke it wont help but just some extra ideas.
I can hear a click when I pull the lever but there isn't any resistence when pulling it like there usually is. I did try pulling up the hood too. And with the endlinks after about 6 hours just sitting and staring at the bolts I just went ahead and took the angle grinder too 'em.
sometimes my hood sticks down after i pull the release, doesnt even move. so i just pull the release a few times and lift UP on the hood. u stated your pushing down. is your car suspended upside down in the air?
Sorry for the late update, I was finally able to get it open by pulling the cable from underneath the car. The latch mechanism was all rusty and sticking, so I cleaned it off and sprayed some wd-40 on it and it works for now. I have a feeling I'll need to replace in a few month though.
