Hot Air Only ???
Old Apr 27, 2009 | 08:20 PM
galeblanc's Avatar
Hot Air Only ???
Hi,
I have a problem today. When I put my ventilation on in my car at the coldest setting, it's only hot air that's coming out (very hot).
Any idea what this could be? Can it be related to my cold air intake at all?
Thanks
Gabriel
Old Apr 27, 2009 | 08:21 PM
BLAZIN07SS's Avatar
I'm too JDM for you
is the button with the snowflake on?
the one in the middle, to the left
Old Apr 27, 2009 | 08:22 PM
zay52790's Avatar
lol, id be surprised if the guy didnt realize his a/c was off
Old Apr 27, 2009 | 08:26 PM
Jmarie619's Avatar
ahahaha thats what i was gunna say :]
gotta make sure the snowflake is on
Old Apr 27, 2009 | 08:27 PM
galeblanc's Avatar
Haha, i've had the car since 2006 so I know that. Thank for the clear picture though!
Whether I put the A/C button on or not, I only get boiling hot air (not boiling cause air doesn't boil but you get the point).
Any more ideas?? lol
Thanks!! Haha!!
Old Apr 27, 2009 | 08:28 PM
TPRMcfly's Avatar
might have some valve stuck open
Old Apr 27, 2009 | 08:54 PM
1niceLS's Avatar
Sounds like you need to get your ac recharged
Old Apr 27, 2009 | 08:56 PM
chevysssc's Avatar
agreed
Old Apr 27, 2009 | 08:59 PM
galeblanc's Avatar
But this could cause only hot air to be generated when the ventilation (without the A/C Button) is on??
Would this be covered under warranty?
Old Apr 28, 2009 | 12:22 PM
DaBuzzard's Avatar
Blend door has failed or is stuck in the heat position, or something in the control end (temperature setting) has bitten it.
If you still have your 3/60* warranty it should be covered.
And a cai will not cause this, no relation to the climate control system whatsoever.
* thats 3/36 for our neighbors
Old Apr 28, 2009 | 12:39 PM
1niceLS's Avatar
If does need to be recharged I don't think the stealership is gonna cover it. Now if it is faulty manufacturer equipment that is causing the problem then it should be covered as long as you still have a warranty left. My advice take it to them and ask them whats wrong if they say somethings broken make them fix it. If they say it needs to be recharged take it to an ac shop and have it recharged or go to autozone and pick up a couple cans of R134a refrigerant and do it yourself.
Old Apr 28, 2009 | 03:30 PM
DaBuzzard's Avatar
No. The air coming in is being directed over the heater core. In winter, this is a good thing.
If the blend door is not operating correctly it will continue to direct air through the heater core and heating it instead of directing it around the heater core and not heating it.
And again, if you are still under the 3 year 60000km, it should be covered.
Old Apr 29, 2009 | 12:45 PM
galeblanc's Avatar
I called yesterday and my warranty just ended 7 days ago. I'll bring it to a local shop and see what they come up with. I'll let you guys know Monday when I bring it.
Hopefully it's a broken hose or something. Is it possible I would have broken a hose while installing the CAI? HAs that ever happened to anyone?
Old Apr 29, 2009 | 02:02 PM
DaBuzzard's Avatar
7 days? They should goodwill it. Mind you, with the state of GM's finances.........
Don't think you would get anywhere near the climate control bits doing a cai install but.....?
Good luck!
Old May 2, 2009 | 02:21 PM
galeblanc's Avatar
Good luck!
Yep, I've got my appointment with my local repair guy who usually only works on my winter cars! lol
But now my warranty is done so it's time to go seem him with the Balt! He's very competent and I'm not too concerned. Hopefully he'll fix the problem.
Now, whenever I put the Vent or A/C there's a lot of whisteling noises? Any ideas now?
Old May 3, 2009 | 05:07 PM
1niceLS's Avatar
If its just a very faint whistling its no big deal almost everbody's balt does it its common. Usually you'll here it most when the setting is on 1 or 2 any higher and the air coming through your vents just muffles the sound. So if this is your problem don't be conerned it's normal.
Old May 3, 2009 | 05:18 PM
JsavageSS/TC's Avatar
They should have made the SS with automatic air, like the Chevy LTZ model cars..... sorry, I'm drunk
Old May 3, 2009 | 11:14 PM
AzulitoAlero's Avatar
I wouldnt get to worried about the blend door actuators and such quite yet
When these cars get a little low on freon, it will shut off the a/c compressor to save it. Go get ur a/c charged and a leak test done at a local shop. should cost ya about 80 bucks on average. It is very possible that you are just low on freon from a miniscule leak, or from normal evaporation over time.
Old May 4, 2009 | 03:16 PM
galeblanc's Avatar
The thing is I get super hot air when my A/C isn't even on. Usually when you put the ventilation on without A/C it's still relatively cool unless it's very hot outside. It's as if I'm getting air direct from the engine.
My mechanic change the motor that controls the hot / cold valve, so we're hoping the problem gets fixed. I'll keep you posted.
Old May 4, 2009 | 10:41 PM
oh yeh. my car does that too. funny thing, it doesnt affect my a/c or heat temps though. But yes, blend doors is what that sounds like. BIG labor hours for a job like that...
Old May 5, 2009 | 10:09 AM
galeblanc's Avatar
I had the motor that controls the gate replaced yesterday and my problem seems to have gone away ... knock on wood.
It only cost 125$ canadian so i'm hoping the problem is settled for good!!
Old May 5, 2009 | 11:54 AM
DaBuzzard's Avatar
$125 ? Good deal
Glad to hear it's fixed
Old May 5, 2009 | 11:59 AM
Gestapo007's Avatar
go get your AC recharged. Your compressor might be bad, or you might have a leak in your AC lines letting the **** out. Maybe your condensor is damaged or has a hole in it.
Old May 5, 2009 | 12:35 PM
galeblanc's Avatar
I'm going to run it out, cause it's working 100% right now, no whisteling either. If it messes up again, I'll bring it back to the shop!
Old May 21, 2009 | 06:15 PM
galeblanc's Avatar
UPDATE: Today we had a really warm day and my problem has come back. Now when I put the A/C on I get about 5 minutes of super hot air and then 2 minutes of cold air and then hot air, cold air, hot air, etc...
Any ideas what my problem may be?
Thanks
no_ss
Oct 18, 2015 11:58 PM
z28addiction
Sep 28, 2015 12:03 AM
grampss
Sep 27, 2015 08:51 PM
DocSvensk
Sep 27, 2015 02:24 PM
OrangeCoba
Sep 25, 2015 06:06 PM
