got a code yesterday
Old May 21, 2009 | 06:52 PM
nybull05's Avatar
ok yesterday my engine light came on and i checked the code and it was 0449. i checked it and this is what it was P0449 Evaporative Emission Control System Vent Valve/Solenoid Circuit Malfunction. now i deleted it and it didnt come back on for the ride home. but this morning it came back. deleted and came back again. i did check my gas cap and it is good. so does anyone know what else this could be or direct me what to look for. and idea would help me out thanks.
any body help me out
Old May 21, 2009 | 11:50 PM
Coblasts's Avatar
That code is set when the valve is commanded open and not seen opening.
Check the connector for corrosion at the valve or broken wiring.
Worse case scenario you will need a new valve.
Old May 22, 2009 | 12:28 AM
nybull05's Avatar
i was trying to figure out where this is located. is it to the right of the valve cover. just not sure where to look
Old May 22, 2009 | 12:34 AM
Coblasts's Avatar
It located on the right side of the engine ,right beside the valve cover.A hose goes in and out of it.
Made a mistake thats the purge solenoid the vent solenoid is located at the back of the car behind the gas tank.You will see a cannister there with the connectors on it.
turbochargedss2012
Sep 20, 2023 12:17 PM
DarrenGC
Dec 24, 2021 01:55 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
ernnyyes
Oct 2, 2015 05:16 PM
Extremespeed
Sep 29, 2015 04:34 AM
