how do u fix
Old Aug 12, 2009 | 03:18 PM
crazywhiteboy89's Avatar
how do u fix
-P0300 Random/Multiple Cylinder Misfire Detected how do u fix it
Old Aug 12, 2009 | 03:27 PM
eurochevy's Avatar
cure unknown..a few of us suffer from it including me
Old Aug 12, 2009 | 03:36 PM
megaman311's Avatar
when was the last time the fuel filter was replaced? Low fuel pressure will cause random misfires. Or the cam/crank shaft position sensor.
Old Aug 12, 2009 | 03:50 PM
Brian MP5T's Avatar
Could be anything from dirty injectors, low fuel pressure, shitty or malfunctioning spark... Bad gas..
Old Aug 12, 2009 | 05:43 PM
o that suck could it beause i need bigger injectors, and it suck cause i hit the gas and it misses and bogs and than takes off
Old Aug 12, 2009 | 05:45 PM
1BADSS/SC's Avatar
sounds like spark plug gap is off or the spark plugs need to be replaced. I would gap them to .035 or less if I were u.
Old Aug 12, 2009 | 05:51 PM
Mindrot's Avatar
That's like asking what causes cancer
Old Aug 12, 2009 | 06:15 PM
megaman311's Avatar
you don't need bigger anything. Maybe just maintenance. Like I mentioned before, the fuel filter will cause you to run lean. It needs to be replaced every 30k miles. This could very well be the cause, or bad plugs. But unless you have 100k miles, the plugs should be fine under normal driving conditions.
Old Aug 12, 2009 | 06:18 PM
harryresh's Avatar
i had this same problem. it was only misfiring at idle. i had a shop run cleaner through my injectors then blow them out. he also changed the timing a little. i was showing no misfires while on throttle.
Old Aug 12, 2009 | 07:26 PM
Brian MP5T's Avatar
Holy ****, I think this car is gonna blow it's motor..
"WHY THE **** WOULD YOU STOMP ON THE GAS IF YOU KNOW YOU NEED BIGGER INJECTORS"
Old Aug 13, 2009 | 01:23 AM
megaman311's Avatar
FUEL FILTER, more than likely is the cause.
dieGone
Oct 1, 2015 06:27 PM
Tupp
Sep 30, 2015 08:18 PM
yellow dragon
Sep 28, 2015 09:49 PM
SlowSaturn
Sep 28, 2015 11:03 AM
jmelton327
Sep 26, 2015 10:04 PM
