How do you clean the LSJ mass air flow sensor?
Old Oct 3, 2012 | 04:20 AM
IROCZ0r's Avatar
I've used the search tool for threads regarding cleaning the MAF, but I've found nothing specific enough in regards to how to actually clean it. I want to know what I'm supposed to be doing before I start messing with stuff on the car.
My car is having a problem going into limp mode under hard acceleration. I got the code scanned and it was related to the MAF, though I didn't bother to remember the exact code.
The most basic solution is to clean the MAF. Which is simple in theory. Get a can of CRC MAF Cleaner and spray the **** out of it.
Problem is, most MAFs look like this, and you spray it into the cylindrical part:
However, when I google what the LSJ MAF looks like, it apparently looks like this:
So, what am I doing exactly? Which part of this needs cleaning, and where am I directing my spray?
Old Oct 3, 2012 | 05:07 AM
OneCOLDBIZL272's Avatar
Clean both opening on the maf. Go to the auto store and by maf/ electrical cleaner. Just unplug your maf take it out. And spray it for about three secs at a pop about 2-3times and put it back in after a few mins. Pretty easy.
Old Oct 3, 2012 | 05:13 AM
If it happens a lot. Have a tuner look at your tune. Your maf scaler/ feq might be off. Or you might have a bad maf.
Old Oct 3, 2012 | 05:15 AM
When I got an intake (my first mod back in 2005) because the intake this happened to me. Try cleaning the maf first.
Old Oct 3, 2012 | 06:11 PM
bluebalt07's Avatar
Just pull the sensor out and saturate the opening in short bursts. The can says like 10 times then just let it dry. It evaporates quickly so after like a minute it will be dry.
Old Oct 4, 2012 | 01:26 PM
nhanson's Avatar
Yup
Old Nov 4, 2015 | 08:58 PM
'05SSSC's Avatar
Does anyone know where the MAF is even located? Im struggling to find it.
Old Nov 4, 2015 | 09:13 PM
For the lsj I believe you have to remove the driver side headlight to get to it
Supercharged06SS
Dec 11, 2022 04:47 PM
DarrenGC
Dec 24, 2021 01:55 PM
Jan 12, 2016 12:01 AM
goaliemo
Sep 28, 2015 01:37 PM
grampss
Sep 27, 2015 08:51 PM
