How to idler pulley
Old Apr 2, 2022 | 12:42 AM
Codester291's Avatar
How to idler pulley
Hey guys how do I remove the idler pulley? There seems to only be like 2 inches of room to work, will I still be able to get the bolts out?
Old Apr 4, 2022 | 03:25 PM
USMCFieldMP's Avatar
Rattlesnake Race Shop
Idler is one bolt. There's an access window in the passenger wheel well that gives access to the bolt.
Better question: why do you need to remove it?
Old Apr 4, 2022 | 03:28 PM
lol you just replied to my p0017 issue. I made a mistake and thought that this pulley was the one makeing the noise, turns out it's the Ac clutch, do you have any pointers on how to take that one off?
Old Apr 4, 2022 | 04:32 PM
What kind of noise? Squeaking/squealing? That's most likely your tensioner needing to be replaced.
If it truly is the A/C pulley, you're probably going to need to replace the entire A/C Compressor.
Old Apr 4, 2022 | 04:34 PM
it's not the tensioner I already replaced it, I took off the belt and spun each pulley and noise was coming from the Ac one, grinding and a squeaky because metal on metal.
Old Apr 4, 2022 | 04:44 PM
It'll probably be easier to replace the entire A/C Compressor. I'm not sure you can get just a new pulley for those compressors... and since they're a clutched setup, I wouldn't think it'd be an easy replacement, either.
Old Apr 4, 2022 | 04:45 PM
On rock auto I can get a ac compressor clutch set, with pulley for 70 bucks vs a 300 dollar compressor.
Old Apr 4, 2022 | 04:55 PM
Interesting. I do have a spare A/C Compressor in my garage. The pressure plug has been blown, but the pulley assembly should still be functional. I might try looking at it to see how easily it can be removed. Hopefully the pulley doesn't need to be pressed off - I wouldn't think so. If you're doing the work yourself, that can be savings. But if you're having to pay someone to change it, it might end up being cheaper to just get the new A/C compressor.
Old Apr 4, 2022 | 04:57 PM
Interesting. I do have a spare A/C Compressor in my garage. The pressure plug has been blown, but the pulley assembly should still be functional. I might try looking at it to see if it can be removed.
that would be awesome, even just to find out the bit size. Because I don't want to strip anything.
Old Apr 4, 2022 | 05:00 PM
I edited that post with more info. Hopefully the pulled doesn't need a pulley remover or press to come out, otherwise it'll get more expensive.
Old Apr 4, 2022 | 05:38 PM
Thanks. I do everything myself, dont wanna go broke more then I already am 😂
racehtecobalt
May 19, 2009 04:18 PM
racehtecobalt
May 19, 2009 11:56 AM
Superchargimus Prime
Oct 23, 2007 09:11 PM
nolimitzss06
Mar 20, 2006 06:50 PM
