how many people have changed their sc oil and had problems?
Old Oct 13, 2008 | 07:08 PM
Jkunzy1690's Avatar
like the title says.. im just wondering if people had problems after changing their factory sc oil
Old Oct 13, 2008 | 07:10 PM
Herndon_High_SS's Avatar
You shouldn't have problems regardless unless you messed up something while changing your oil.
Old Oct 13, 2008 | 07:17 PM
Jkunzy1690's Avatar
how much did you put in... i put sbout 6oz in
Old Oct 13, 2008 | 09:55 PM
Tennpenn83's Avatar
eaton says the oil is good for the life of the supercharger... you shouldn't have to
Old Oct 14, 2008 | 09:51 AM
rnjmur's Avatar
True... however the life of the SC is only 100K. So if you are hoping to run it more than that you may want to change the oil. Also, when running a smaller pulley you do create a bit more heat, so it is a good idea the change the oil.
Old Oct 14, 2008 | 10:31 AM
Tennpenn83's Avatar
guess it depends on how small a pulley you want to run. the most efficient pulley (per eaton) is the 2.8
idk, if i ever service the blower, i'll prob port/polish it while i'm at it along with changing the oil, or just upgrade to the tvs
Old Oct 14, 2008 | 10:43 AM
383_Stroker's Avatar
I changed mine with no problems....
Old Oct 14, 2008 | 11:45 AM
Dainslaif's Avatar
From what people have said, the only common problem that results from an oil change is overfilling. ZZP says it's 6 ounces but a LOT of people argue it's only 4.
If you overfilled and it ruins anything it will blow the seal at the snout and start leaking out. AFAIK this is the only symptom, so if your engine bay is coated with SC oil that seal probably went out.
Old Oct 14, 2008 | 05:18 PM
JapEatr's Avatar
South Central *********
changed mine, 4 oz , no probs, ported it the same time
DarrenGC
Dec 24, 2021 01:55 PM
brandon04
Oct 21, 2015 07:04 AM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
roth
Sep 26, 2015 12:16 PM
