How messed up is this bs
Old May 4, 2010 | 02:00 PM
roser4888's Avatar
So i was in an accident that did $3500 worth of damage to my ss/sc. After the accident i nticed the clutch pedal was stiff and the only way i could put it in 1st gear was to shut off the vehicle and put it in. Then to take off i would not push the clutch in and the car would lurch untill it took off while i was cranking it over. When driving i push in the clutch and the rpms do nothing. Its like my clutch will not disengage. Now im told that it is not accident related, how is possiable to not be related if it wasnt that way before?
Old May 4, 2010 | 03:18 PM
chris88z24's Avatar
Sounds like the MC is FUCKED.
Old May 4, 2010 | 05:17 PM
roser4888's Avatar
sounds like the mc is fucked.
wouldnt my brakes be hard to? I thought the brakes and the clutch use the master cylinder.
Old May 4, 2010 | 06:22 PM
DaBuzzard's Avatar
Brake and clutch systems use the same resevoir but seperate master cylinders.
Think about it, if they used the same master, you would be locking up the brakes every time you hit the clutch.....
Old May 5, 2010 | 07:07 AM
roser4888's Avatar
Originally Posted by dabuzzard
brake and clutch systems use the same resevoir but seperate master cylinders.
true, never thought of it that way
Old May 5, 2010 | 07:15 AM
PSHHH's Avatar
Ur luck isn't in ur favor lately.
Old May 5, 2010 | 07:16 AM
roser4888's Avatar
Hell no its not
Old May 5, 2010 | 07:24 AM
n323er's Avatar
What he said this happened to me 2 years ago.
no_ss
Oct 18, 2015 11:58 PM
Iceberg
Sep 29, 2015 12:33 PM
Iceberg
Sep 28, 2015 01:31 PM
jmelton327
Sep 26, 2015 10:04 PM
