Howto Check battery?
Old Nov 29, 2006 | 03:03 AM
bdwarr6's Avatar
how can i check to see if my battery is bad?
Old Nov 29, 2006 | 07:35 AM
e to the x's Avatar
What do you mean by bad?
Old Nov 29, 2006 | 08:22 AM
splink's Avatar
take it to an advance auto or any auto parts store should be ableto check it for you.
they hook it up, run a charge on it and check it out completely
edit...shouldnt cost anything either
Old Nov 29, 2006 | 08:35 AM
alleycat58's Avatar
^^^^^^That is the easiest, most pain-free way to do it. But you can also use a voltage meter if you have one. If you've got a dead battery you're probably also going to want to have the dealer check the alternator. Batteries should last 5 years or more...if you've got an issue this soon, that'd point to an alternator problem in my mind.
Old Nov 29, 2006 | 08:37 AM
e to the x's Avatar
I think he's worried its frying his ECU since he's on his 3rd one now.
Old Nov 29, 2006 | 08:46 AM
alleycat58's Avatar
Ah. Could be. I'd have the full electrical system checked though anyway, I had that problem on my Cavalier. Bad battery killed the alternator, which killed a good battery, which killed the new alternator, turns out there was a problem somewhere else in the electrical system that was causing the whole mess.
rally's Avatar
Grab a Digital Multi Meter (you can get one for like 7 bucks at walmart, and it sucks for most purposes but will work fine for this) Take your black lead place it on the negative, red lead (positive) on the positive terminal and turn your dial to VOLTS. Battery should read anywhere from high 11's to 12.10 or so.
Old Nov 29, 2006 | 03:38 PM
tcolli17's Avatar
Take it to autozone. they will tell you if it is holding a charge, something you can't check with a multimeter.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
brandon04
Oct 21, 2015 07:04 AM
yellow dragon
Sep 28, 2015 09:49 PM
grampss
Sep 27, 2015 08:51 PM
c_m_shooter
Sep 27, 2015 04:40 PM
