Hunting1961
Do you mean heat exchanger pump? There is a bypass solenoid that has a line that runs to the bottom nipple of your "bypass valve" that is attached to the supercharger. I am having a hard time understanding which one you replaced and have no idea what pump you are talking about.
Jdbaugh1
The pump on front of superchager that antifreeze runs through. we tested it and was not working. After we put the new one in we still had no boost than we replaced the bypass solenoid. We are not sure on what to check next. I guess the next thing we are looking at doing is make sure the solenoid that is at the throttle is working properly. I understand that the solenoid has a rod that moves with the vacuum. So we are going to check to make sure it is also working properly if not I'll replace it as well.
