I don't know what is wrong
Old 08-17-2015, 07:02 PM
danielbone's Avatar
I have a 2009 cobalt ss turbo charged. Recently my check engine light came on and my car has no power almost like my turbo isn't producing any boost. I took it to a local mechanic and he said it came back as a bad fuel pump. So they replaced my fuel pump and went to go pick my car up from them and the check engine light is still on and my car still has no power. Also when I turn it off sometimes it doesn't want to start It will just keep cranking until I turn the key off I have to do this multiple times before it will finally start. And as I was backing my car up from his shop I just held the clutch in and rolled backwards it sounded like the whole underneath of my car was dragging the gravel. Any ideas would be much apriciated.
Old 08-17-2015, 08:07 PM
tomj77's Avatar
Did they change the in tank pump or the high pressure pump which is what it probably is, that is on ur motor? 20 bucks says they changed the wrong one
Old 08-17-2015, 08:13 PM
danielbone's Avatar
They changed the one in my tank
Old 08-17-2015, 08:18 PM
What codes do you have?
Old 08-17-2015, 08:44 PM
danielbone's Avatar
I dont know the codes I didn't get to see them the mechanic just said it had like 3 different codes all for the fuel pump that came up
Old 08-17-2015, 08:58 PM
Yeah then i guess it could be the high pressure one thats on top of the engine
10-20-2015 09:56 PM
no_ss
10-18-2015 11:58 PM
dieGone
10-01-2015 06:27 PM
Stuff
10-01-2015 05:47 PM
Quick Reply: I don't know what is wrong
