i neen help, car wont start
Old Nov 3, 2009 | 09:38 PM
WHITE G5's Avatar
my car wont start, ive tryed reseting the battery and checking the fuses.. the inj fuse dosent seem burned but wont turn on with the fuse cheker. is it suppost to? my dic reads POWER STEERING, its never said that before. what can it be?
Old Nov 3, 2009 | 10:09 PM
RooTBeeR's Avatar
i have no idea, find someone close to you with a scanner, code reader and see if your throwing any thing
Old Nov 3, 2009 | 10:31 PM
ColeJJones's Avatar
Bannned
had this happen to me. does a key appear anywhere? it was a fuse that blew in mine. everything would light up but wouldnt start. i forgot what fuse it was... its one of the ones in your engine bay. im mad cause i forgot! it was a year and a half ago. but its just a lil 10 or 12 fuse
Old Nov 3, 2009 | 10:47 PM
Coblasts's Avatar
If the car doesnt turns over
1)check the clutch switch
If the car turns over
2)check the fuel pump fuse
3)Open up the underhood fuse box and place your finger on the PWR/TRN relay and have some one turn the ignition on, You should feel this relay energize.
The inj fuse is fed from it.
For the power steering check the EPS fuse 60 amps
Also the Emiss fuse
Old Nov 3, 2009 | 10:56 PM
nicksredline's Avatar
there is a problem with the redlines that u have to wait for like 25-30 min before starting the car after inital crank.. if it starts after that its a cold start problem... thre is a 25 dolor switch( ignition) it just reads that ur key is the right 1and sends the coad to turn on ur car)
Old Nov 3, 2009 | 11:02 PM
WHITE G5's Avatar
thanks guys ilil try this stuff tommprw mourning
Old Nov 4, 2009 | 05:16 PM
WHITE G5's Avatar
nothing seemed to work, can i be the computer? my radio, interior dome ligth, windows, and door lock wont work.
would a computer scaner tell me whats wrong with it? enev though the check engine light aint on?
bumb
Coblasts's Avatar
Okay check the 50 amp fuse in the trunk near the battery.
Its a inline fuse that protects the feed to the Bcm.
Old Nov 4, 2009 | 05:41 PM
WHITE G5's Avatar
bumb
is it okay jt to pull it out or do i disconent the battery first
Old Nov 4, 2009 | 05:43 PM
Coblasts's Avatar
If this 50 amp fuse is fine I would say theres something wrong with the bcm.
Another question:Are you telling the whole story here.
Were you doing something or working on something when you then noticed that the car wouldnt start ?
WHITE G5's Avatar
dude i luv u,, that fuse was the problem
Old Nov 4, 2009 | 05:48 PM
Coblasts's Avatar
But Now you have to ask ,what blew a 50 amp fuse
Either you shorted a wire out and failed to mention it or you have a major problem that replacing the fuse isnt going to solve.
a major short could still be present.
Let me know what happened or happens in a pm.
hawkssoccer11
Sep 30, 2015 12:14 PM
Wind
Sep 11, 2015 06:57 PM
Getaway_Driver
40
Sep 10, 2015 09:11 AM
Getaway_Driver
Sep 8, 2015 09:41 AM
Getaway_Driver
25
Sep 5, 2015 09:16 PM
