IC pump
Old Jul 31, 2008 | 11:11 AM
hatrickstu's Avatar
IC pump
For some reason i dont think my IC pump is pumping. anyone know of a foul-proof way of testing it?
Old Jul 31, 2008 | 11:14 AM
BOOSSTED 06's Avatar
turn the car on, check under your hood if the filler neck is kind of bubbling
Old Jul 31, 2008 | 11:15 AM
hatrickstu's Avatar
should it take a certain amount of time or coolant temp?
Old Jul 31, 2008 | 11:16 AM
even at idle the little filler neck should have the fluid moving a little bit.
If you have an interceptor gauge, just check your iat2's if they dont drop while your driving a round the fluid isnt flowing
Old Jul 31, 2008 | 11:22 AM
Ahriman's Avatar
there should be a significant amount of flow through the filler neck. if you even think it might not be flowing cuz its hard to tell then it probably isnt.
easy fix though, get the pump from a ford parts dealer for about 80 bucks, and with the right tools it can be swapped in under an hour.
Old Jul 31, 2008 | 12:23 PM
hatrickstu's Avatar
**** that, this bitch is under warranty. its not flowing. no wonder my intake temps have been ridiculous
anybody know which fuse is the intercooler fuse?
problem fixed. take a hammer to it
Last edited by hatrickstu; Jul 31, 2008 at 12:23 PM. Reason: Automerged Doublepost
Old Jul 31, 2008 | 12:25 PM
invisible's Avatar
A hammer got you're pump working again?
Old Jul 31, 2008 | 12:36 PM
hatrickstu's Avatar
yep. talked to a view lightning guys and they say its a common problem for some IC pumps to "clog" temporarily. unclogged pump likes me again
Old Jul 31, 2008 | 12:39 PM
invisible's Avatar
Thanks, Im gonna have to try this cause my 2nd h/e doesn't ever get hot and sometimes barely warm...
Is it easy to tell its moving even if it isn't hot?
hatrickstu's Avatar
if you have fluid pumping this isnt going to help with that. i had literally NO fluid pumping
Old Jul 31, 2008 | 12:41 PM
invisible's Avatar
Thats what I am trying to say. The second h/e should be atleast warm when I drive home don't you think?
Old Jul 31, 2008 | 12:44 PM
hatrickstu's Avatar
not sure. is it the first one in the system or the second one?
Old Jul 31, 2008 | 12:48 PM
invisible's Avatar
Second.
Cobra H/E
hatrickstu's Avatar
thats probably why. its not against any heat radiating objects and its cooling down fluid already cooled down once
Old Jul 31, 2008 | 12:57 PM
invisible's Avatar
Thats what I am hoping for. Just kinda worried cause I don't have anyway to moniter IAT's but I do have meth so that is a little bit of a safety net. lol
Old Jul 31, 2008 | 01:00 PM
USMCFieldMP's Avatar
Rattlesnake Race Shop
In the future... know that the pump is a simple 12 volt system. Its on when you start the car... its off when you turn it off.
You can test it by hooking up an outside 12V source.
Mine died last year. Was a bitch.
Old Jul 31, 2008 | 01:01 PM
hatrickstu's Avatar
oh i know that man, i just didnt have a voltmeter
Old Jul 31, 2008 | 01:06 PM
invisible's Avatar
How much do they cost?
Old Jul 31, 2008 | 01:07 PM
hatrickstu's Avatar
not real sure. i have one at my parents house that i usually use
Old Jul 31, 2008 | 01:08 PM
invisible's Avatar
Haha lol, I'm sorry, I meant the IC pump.
Old Jul 31, 2008 | 01:09 PM
hatrickstu's Avatar
not sure. probably not terribly expensive
Old Jul 31, 2008 | 01:14 PM
victory_red_SS's Avatar
LSX RWD S/C conversion
A member's IC pump died and it cost almost $400. to get another one from GM.
On top of that these pumps are supposedly as cheap as they come and they will die sooner than later.
Old Jul 31, 2008 | 01:15 PM
That's why you get a Lightning/Cobra pump off of eBay.
hatrickstu's Avatar
well you dont necessarily have to run another GM one. like one guy said you can get one from ford for $80. i dont know the validity of that though
Old Jul 31, 2008 | 01:17 PM
invisible's Avatar
I am guessing that it will fit in the cobalt brackets? Does it flow anymore cause if you could get one that does, i would think it would lower IAT2's a little.
