ignition module
Old Nov 19, 2008 | 07:14 AM
lightinbalt's Avatar
ignition module
Ok so my car keeps frying ignition modules, on my 3rd one know, and it also blows the ignition fuses and other fuses in the fuse panel under the hood. any one have this problem or could give me an idea of what the problem is. also it has been in a local shop and they just replaced the fuses, battery and module and said it was fixed.... I dont have the money to take it to the dealer. anyone that has ideas i am willing to try anything.........
Old Nov 19, 2008 | 07:16 AM
umrdyldo's Avatar
Maybe a short in wiring.
Hey also I remember some people having problems with certain spark plugs killing the ICM. Have you changed them to something different?
Old Nov 19, 2008 | 07:22 AM
they are the same as stock, just changed them after the last time replaced the ignition module
Old Nov 19, 2008 | 07:29 AM
originaladrian's Avatar
have they ever replaced ur fusebox? i had a short under mine.
the one in the engine bay
Old Nov 19, 2008 | 07:34 AM
how much does that cost?
Old Nov 19, 2008 | 07:37 AM
not sure, was done under warranty.
Old Nov 19, 2008 | 07:53 AM
cobalttuner4698's Avatar
Hey...im on my second ignition module now...try changing the sparks. My dealership said that it can cause them to go...wich eventualy could lead to the igmod goin again... Also said that it could be a bad module. we'll see what happens though...mine went 2 in one month. One more month to go and we'll see what happens....keep us updated if you find out any more...
Old Nov 19, 2008 | 07:14 PM
Coblasts's Avatar
Does the 2.2 Have the ignition module that connects to all four plug or the singles.
Im asking this if maybe it is one paticular module that is going ,say #4 plug all the time.
If you changed the plugs and there is a higher than normal internal resistance it would draw more current and cause premature failure of the module.
Avoltage drop on the feed wire for the module due to a resistance in the circut could do it as well as a short that interupts the voltage (wire shorting to the head repeatedly).
Also check your voltage at the battery while the car is running should be around 14 to 15.5 volts dc.
Old Nov 19, 2008 | 07:20 PM
also, if u have a large system the draw at startup might be putting a big strain on ur car. If u do have a system make sure cars electrical system is properly supported with thick wire and stiffening caps
Old Nov 19, 2008 | 10:55 PM
no system on mine car...just stock sub which draws nothing. haha.....Come to think of it..i do remember the tech that worked on my car saying that their was a misfire with one of the plugs. but never said which one......
makes me wish i had a tuner or a gauge that would say if they were misfiring.
Old Nov 20, 2008 | 07:04 AM
ur comp will record all misfires. If u had one it would show up on an obd2 scanner.
(if u go to Advance auto or some place like that they will let u use one for free)
Old Nov 20, 2008 | 09:36 AM
the plugs were changed, but they were changed oem plugs, how do i check for a voltage drop in the feed wire, there are no wires exposed around the head.
the 2.2 has direct fire ignition just like the rest of the ecotecs....
Old Nov 20, 2008 | 10:35 AM
my plugs were changed in mine as well...so hopefully that helps...found a OBD2 Scanner on ebay...3.25, 20 bucks shipping. haha may look into getting that just incase something happens again....;Originaladrian....what do u think?...worth getting one on of those or?...
Old Nov 20, 2008 | 11:55 AM
yup there great, just make sure u get a decent one, some people have been saying that older model obd2 scanners are not working properly.
Old Nov 20, 2008 | 03:12 PM
How do u tell whether it is a late model or not?
Old Nov 20, 2008 | 03:16 PM
Grich171's Avatar
if you had a misfire you would throw a check engine light on.... late model means like a newer-ish car
Old Nov 20, 2008 | 03:24 PM
think he originaladrian was talking about the older scanners...and ya...my check engine light was on...i'd just like to know which one is misfiring
Old Nov 20, 2008 | 10:16 PM
Grich171's Avatar
you could pull coils individual n what ever one doesnt change the idle is prolly the one thats misfiring
Old Nov 21, 2008 | 06:51 AM
its not the coil that is the problem, its the module...
ricklovin93
Aug 27, 2016 06:35 PM
Shanman
ZZ Performance
43
Aug 26, 2016 08:43 PM
satisfied
Oct 19, 2015 12:35 AM
reybalt
Sep 25, 2015 08:28 PM
Cptnslo
Sep 24, 2015 09:32 AM
