ignition problem
ignition problem
ok so i jut got a call on an 07 cobalt na.......(im a tow truck driver fyi).....any way i get there and the car will not turn off the key wont turn either way had to pull the fuelpump relay to turn it off and disconnect battery to prevent theft any body else run into this if not be careful may happen to any of us
its happened before, there is a manual release switch in the steering column. dont exactly know where but there have been some threads on it. search but can you say dealer time!
