The Infamous P0496
Hey guys whats up? Now I know people have had the same problem as me because I was smart and searched the forum before I decided to post.
Here is my question though. For some reason my car always starts up first try no problem unless I am at the gas station. Once I put a new tank of gas in the car and go to start it, it justs sits there forever and tries to turn over. The only way it will start is if I hold down or pump the gas. As soon as it starts though If you let off the gas it dies. I have to ride the clutch and gas for the first mile or else it will die. After the mile it runs just like normal. Now I am not very knowledgeable on these cars. So here is my question. What could be causing this and is it something I can fix on my own. I have to fix this ASAP cause I am a Part Time Firefighter
and I need my car to respond to calls. Any help would be greatly appreciated.
first things first
Genuine Pontiac Vapor Canister Purge Valve 2010 - 2010 - eBay (item 320580839663 end time Mar-22-11 12:21:39 PDT)
looks like prices doubled since i bought mine, but if you get that purge valve and swap it out your code will be gone, and it might fix your gas problem too since it does have to do with fuel tank pressure and all that emissions crap lol
thanks man. and rootbeer there are two valves, one on the engine the purge solenoid and the one on the canister the vent valve. the purge solenoid is the one that usually goes bad on these cars. and causes these issues ( the one you posted is the purge solenoid anyways not the vent valve)
Its the one on the motor guys read the thread. The vent valve is by the charcoal canister out back on the tank. And yes u can clear it but the condition will happen again. We tuned my car with the solenoid bad big mistake after i replaced it shes rich as fauk
Hey man I know these are old post but my lnf is having this problem now anyone know how to fix it? It struggles to crank when I put gas in it and I can't get it to pass inspection help please!
Lol evap purge solenoid man read the 5th post.
What he said lol.
What he said lol.
The one by the tank is the canister vent valve....,and you don't have to drop the tank to change it. Replace the evap purge solenoid up in the engine bay
and I need my car to respond to calls. Any help would be greatly appreciated.My car did the same thing yesterday I'm bringing it to dealer today only has 37k miles still under 5yr 100k I'll let you knw
SS/SC_Mike
Feb 21, 2009 12:33 AM
Ramphex
Feb 14, 2009 05:17 PM
