Intake air temp reading -40°
Old Jul 27, 2016 | 01:41 PM
Dougsterbob's Avatar
Ive been getting codes P0171 (system too lean) and P0113 (intake air temperature circuit 1 high). When I look at the freeze frame (cause by P0171) I see that my Iat sensor is reading that the air is -40°. I understand that this sensor is part of the MAF? Is that right? This is also after I put on a new MAF. Before the new MAF I was only getting the too lean code, now I'm getting the too lean code along with the IAT circuit temp code. Any suggestions on what I should try to make it go away?
Thanks.
Old Jul 27, 2016 | 03:30 PM
Sl0wbaltSS's Avatar
See if it's the circuit or the maf itself.
Old Jul 27, 2016 | 07:08 PM
What would be the best way to do that?
Old Aug 3, 2016 | 07:36 PM
Anyone?
Old Aug 6, 2016 | 05:31 PM
mrbelvedere's Avatar
get a meter a ohm the wires
Old Aug 10, 2016 | 11:10 PM
I checked the MAF harness the far right prong was reading 5.02 v and the far left was 12 ish v the middle 3 went reading anything. I don't know anything about electrical so I'm completely lost here.
Old Aug 10, 2016 | 11:52 PM
you most likely have an open in the IAT circuit, find out which wire on your maf is iat and trace it back through the harness.
Old Aug 11, 2016 | 09:29 AM
By open you mean like a split wire? Is that what i should be looking for? Thanks
Old Aug 11, 2016 | 10:34 AM
yes, an open circuit, pinched wire, bent pin in maf connector or pcm connector
RyGuy
Apr 25, 2019 09:22 AM
matthud
Jun 9, 2016 11:52 PM
Staged07SS
Jun 1, 2016 10:21 AM
xRedrumisBack
May 14, 2016 02:36 PM
Rdkdiz
May 4, 2016 07:02 PM
