Interceptor doesn't work
Old Feb 19, 2011 | 02:03 PM
Jdam8139's Avatar
So I bought an interceptor from a user on here, and it isn't working properly. Sometimes it takes anywhere from 15-45 minutes to display anything, and sometimes it just doesn't work at all. I saw there was a problem with some of the gauges and the 06 balts (whuddya know thats what I have), but was a solution ever found?
Since I bought it used I fear I'm stuck with a defective gauge
If anyone knows anything I would appreciate the help!!!
...Oh BTW everytime I try to email service@aeroforcetech.com it says the account doesn't exist.
Old Feb 19, 2011 | 02:07 PM
Jdam8139's Avatar
Old Feb 19, 2011 | 02:10 PM
ecot3c inside's Avatar
my display sometimes goes blank as well, kind of dims out. check your power source.
Old Feb 19, 2011 | 02:18 PM
Jdam8139's Avatar
The power source is fine, i have it spliced into the pink wire to the boost gauge and the boost gauge operates fine. The interceptor has to be getting power
SS_NH's Avatar
Are you using the extra power wire?
Old Feb 19, 2011 | 02:19 PM
try hooking it up to a different power source.
now fix my problem....
Old Feb 19, 2011 | 02:21 PM
SS_NH's Avatar
Is the jumper still attatched? I know you have to take that off if you tap it to power.
Old Feb 19, 2011 | 02:22 PM
Jdam8139's Avatar
What extra power wire? I'm using the red wire from the 3wire mini-connector. It works sometimes, it just takes forever to start up, wouldn't that indicate that its getting enough power?
Old Feb 19, 2011 | 02:24 PM
Jdam8139's Avatar
yes the jumper is off
Old Feb 19, 2011 | 02:25 PM
SS_NH's Avatar
You beat me to the post lol.
And I'm clueless then, maybe you dont have a good connection where you tapped it?
Old Feb 19, 2011 | 02:27 PM
Jdam8139's Avatar
Could you take a pic of how yours is wired. I'll take a vid of what it does on startup in a minute.
Old Apr 2, 2011 | 08:44 PM
JshLnsctt's Avatar
I bought one like this and ended up sending it back, it was where the small harness hooked into the back of the gauge, I got it working for a while by using a little electrical tape to hold it the way I needed. Since I got it through eBay I got my money back though. I have a three pillar with three interceptors all working good now though.
dennis69
Oct 20, 2015 04:49 PM
SSLOW06
Oct 1, 2015 07:21 PM
Iceberg
Sep 29, 2015 12:33 PM
Iceberg
Sep 28, 2015 01:31 PM
jmelton327
Sep 26, 2015 10:04 PM
