Issue changing rear brakes
Old May 10, 2008 | 08:19 PM
Evilfrog's Avatar
I'm having a hard time with the rear driver side caliper. I can not compress it even after opening the bleeder valve. The pads that were on it do not look that worn at all. The E-brake is off. Should I take off the brake lines? Has anyone had this happened before? The front calipers compressed nicely. I haven't attempted the passenger side yet.
Thanks.
Old May 10, 2008 | 08:22 PM
Sunburst_SS's Avatar
yea...the rears you need to turn as you press them in.....They hve a turn-screw type caliper for the parking brake
Old May 10, 2008 | 08:30 PM
Evilfrog's Avatar
Turn the bolt on the the back of the caliper that is in the middle of the parking brake spring?
Old May 10, 2008 | 08:33 PM
no.....turn the caliper piston and you press it in
Old May 10, 2008 | 08:37 PM
Evilfrog's Avatar
hmm. Is that why there the two pie piece shape cut outs on the top of the piston? What two would I use to turn it?
Old May 10, 2008 | 08:38 PM
HidKidSS's Avatar
wow i just did my rear rotors an brakes you cnt push them in i thought u could as well like the front...go 2 autozone or pep boy or w.e autostore you have around you tell them your changeing your back brakes an you need the turning tool 2 get the piston back in...they will give u a uni tool thats a cube with lil taps sticking out...makes live 100x more easier then sitting there trying to turn it by hand
the tool will cost about 5-10bucks but just return it when your done if your not going 2 find a use 4 it netime soon
Old May 10, 2008 | 08:39 PM
yup, that's why.....we have a tool at work to use......Personally I just use a pair of needle nose pliers or something...turn and push at the same time
Old May 10, 2008 | 08:43 PM
Evilfrog's Avatar
Sweet. got it. Thanks for the help!
+ rep for everyone! If we still had rep that is.
Old May 10, 2008 | 08:44 PM
no prob.
Old May 10, 2008 | 08:45 PM
HidKidSS's Avatar
no prob bro
Old May 30, 2008 | 08:48 PM
455rocket's Avatar
Yeah great info I just spent an hour trying to get the piston in with my C clamp!
Old May 30, 2008 | 08:50 PM
Dead Zen's Avatar
i just used the open end of a 12mm wrench
Dustin24
Oct 8, 2015 09:15 AM
Builttss
Sep 21, 2015 04:29 PM
Getaway_Driver
40
Sep 10, 2015 09:11 AM
