key fob and gmparts
Old Nov 8, 2010 | 08:36 PM
deereboy4320's Avatar
key fob and gmparts
does anyone know if gmpartsdirect.com sells the key fob. was just wondering if i could buy it there instead of the dealer (might be cheaper)
Old Nov 8, 2010 | 08:38 PM
rnjmur's Avatar
I bought one off ebay. You still have to pay the dealership to program it though.
Old Nov 8, 2010 | 08:49 PM
Fuzz's Avatar
Yeah ebay is your bet. Most dealerships will charge you a 1/2 hour to program. Just curious because i have re-soldered a lot of gm fobs is yours broken or are you just wanting a spare?
Old Nov 9, 2010 | 12:11 PM
well it was broken the when i resoldered it the metal got to hot and then broke when i inserted the battery it broke the metal piece. i want to get a new one though because teh only button that works is the trunk on one of the fobs and the lock button on the other. i was hoping to just find the rubber insert because that is the problem but i cant seem to find one.
Old Nov 10, 2010 | 10:34 AM
Sh0nuff's Avatar
as far as i know if you know someone with hp tuners they can setup a new fob for you, if you get one off ebay, am i correct guys?
Old Nov 10, 2010 | 12:51 PM
rnjmur's Avatar
Not that I know of. The fobs have to be programmed with a tech2.
I had the same problem with my fob, the rubber got "worn out" and wouldn't make good contact anymore. I just bought a fob off ebay then swapped the rubber from one fob to the other.
satisfied
Oct 19, 2015 12:35 AM
Extreme Dimensions
Sep 24, 2015 07:51 PM
Shane H
Sep 20, 2015 11:56 AM
Gugi96
Sep 15, 2015 12:24 AM
jthwjde
Sep 7, 2015 09:24 AM
