Limp Mode Need Help!!!!
Old Mar 12, 2006 | 03:24 PM
SS4LIfe's Avatar
I finished the install on the intense kit yesterday and when i took it out for a test, it was fine for first gear and part of second then the DIC said "ENGINE DISABLE", "POWER REDUCED", and it shut off, then it wouldn't start, so i disconnect the battery reset the computer and ran the codes, now it runs but in limp mode. and everytime i clear the codes they come back as soon as i turn the key on without even starting it. the manuel says take to dealer and they ain't open untill tomorrow, everything is hooked up no leaks.
It also says low coolant
ANY HELP IS GOOD
Old Mar 12, 2006 | 03:33 PM
Cobalt_Supercharged's Avatar
Dstinceman56 ran into this on our trip. He said his TPS came loose. I'm assuming that was the Throttle Position Sensor. Hope that helps.
Old Mar 12, 2006 | 03:37 PM
SS4LIfe's Avatar
i checked and rechecked the plug at the bottom by the throttle and all the codes are throttle related, where is the sensor
Old Mar 12, 2006 | 03:45 PM
That I don't know. Post #185 is where he talked about it, youould always PM him to see if he can help.
https://www.cobaltss.net/forums/show...&page=10&pp=20
Old Mar 12, 2006 | 03:47 PM
Also check the wiring instructions. I guess the picture shows the one wire connected to the wrong lead, but the written instructions have it correct.
Old Mar 12, 2006 | 03:53 PM
SS4LIfe's Avatar
which wire, it was all plug and play, i didn't have to wire anything.
Old Mar 12, 2006 | 03:57 PM
Clmbngfrk18's Avatar
this is kinda stupid but that can happen if you gas cap is loose it doesnt hurt to check right
Old Mar 12, 2006 | 04:00 PM
Oh wait, I just realized that you have the intnse kit Sorry. I must have misread it with a post below or something with the Rev-it Up.
Old Mar 12, 2006 | 04:01 PM
SS4LIfe's Avatar
just checked its good
Old Mar 12, 2006 | 05:22 PM
SS4LIfe's Avatar
P1516 Throttle Actuator Control (TAC) Module Throttle Actuator Position Performance -PCM
P2101 Throttle Actuator Position Performance -PCM
those are the codes
Old Mar 12, 2006 | 05:26 PM
SS4LIfe's Avatar
what does limp mode sound like mine sounds like a go cart misfiring really bad i heard it runs on 2 cylinders when on limp mode i just want to make sure i didn't blow it,
when it happen there was no oil leak, gas, coolant, or smoke so i don't think its blown, is that what limp mode is suppose to sound like
Old Mar 12, 2006 | 05:28 PM
flobeelicious's Avatar
i'll check in the service manual in a bit to look up the codes, see if i can give you a bit more information on them. ellicott city, does that mean that it'll be going to miller brothers?
edit: have you checked with intense yet to see if they have any information on people experiencing similar problems with the kit?
Old Mar 12, 2006 | 05:31 PM
Yeah that's what it sounded like on Dstinsman56's.
Old Mar 12, 2006 | 05:38 PM
SS4LIfe's Avatar
yeah and they did my oil change on friday so i might get lucky and be like what did you do to my car
Old Mar 12, 2006 | 05:44 PM
SS4LIfe's Avatar
yeah i pm him
Old Mar 12, 2006 | 05:51 PM
sunfirejoe's Avatar
holyshit i hope thigns work out for you man real soon
Old Mar 12, 2006 | 05:52 PM
SS4LIfe's Avatar
thanks i might be the 1st to have this type of problem after the intense kit
Old Mar 12, 2006 | 06:02 PM
NJCOBALTSS's Avatar
ANY HELP IS GOOD
my car is in limp mode also, but i only have an intake and a 3.0 pulley,
how do you get the codes without going to the dealer?
Old Mar 12, 2006 | 06:17 PM
SS4LIfe's Avatar
i have a code scanner, plug it into your obd 2 plug, does you run like mine.
Old Mar 12, 2006 | 06:25 PM
autozone will hook your car up to a scanner and give you the codes for free.
Old Mar 12, 2006 | 06:34 PM
DTC P1516
the commanded throttle position is compared to the actual throttle position based on accelerator pedal position and possibly other limiting factors. both values should be within a calibrated range of each other. the PCM continuously monitors the commanded and actual values and sets DTC if values are greater than calibrated range.
conditions for run: ignition on, ignition voltage >8 volts, system not in battery save mode, engine running, dtc P0068 not set.
conditions for setting: difference between preditced and actual throttle position is out of calibration range >.5 seconds
action taken when DTC sets: light, records failure, control module commands TAC system to operate in reduced engine power mode, message on DIC, under certain conditions engine may shut off.
PCM will clear light after 3 consecutive drive trips where diagnostic runs and passes.
DTC P2101 seems nearly identical to me.
most of the tests to verify this don't really seem like anything that you'd probably want to do it at home. i think if i were you, i'd take it up there to them (and uninstall the kit, if possible, just to try to save yourself some hassle if its a warranty repair that could be remotely related to it). overall though, they definitely seem to be more competent than most of the dealers in the baltimore area, who i wouldn't trust to be within 100 feet of my car. and there service manager has been a pretty good guy to deal with, at least for me.
Old Mar 12, 2006 | 06:44 PM
SS4LIfe's Avatar
DTC P1516
thanks man, are you saying if i drive it, it will go away, i set the maf-t to 0 and 0 so that means its like its not there.
Old Mar 13, 2006 | 08:55 AM
silverSS's Avatar
limp mode with a 3" pulley and intake!!!! UH OH!
Old Mar 13, 2006 | 09:02 AM
CobaltSS422's Avatar
Last summer my SS/SC went into limp mode and would not go away! Drove it to the dealer and they fixed it. It was the TPS Sensor and it came loose as I was accelerating (hard). So they put it back in and havent had a probelm since. If it is the sensor it's not going to go away until it's plugged in properly
Old Mar 13, 2006 | 12:54 PM
SS4LIfe's Avatar
ITS FIXED THANKS EVERYBODY
Well what happen is a piece of rubber was stuck in the intake at the throttle and it couldn't close.
i know you are thinking where the rubber came from. Well i changed my spark plugs and i had a crappy spark plug puller and the rubber boot got stuck around the spark plug so i got that off and handed it to my friend and he was playing with it and then he dropped it into the engine bay, then he couldn't find it but no big deal right so i finished up and thats why it went into limp mode, actually one of the guys from this forum was the one who fixed the car for me. carbombss thanks
