LOOK!! header/CEL question
Old Mar 22, 2009 | 10:05 PM
kevinj4891's Avatar
Exclamation LOOK!! header/CEL question
so i have a full exhaust set up...i have Cobalt Addiction V2 header, vibrant downpipe with high flow cat,twin race mufflers....after i installed the set up, i got a CEL (check engine light). i bought a code reader and it read 0420.. i clear the code, but it comes up every day or two.my question......i put header wrap on...did it right and didn't allow too much over-wrap...do you think the wrap is why the code keeps appearing even thoug i have a cat... any suggestions???
thanks
Old Mar 22, 2009 | 10:06 PM
chris88z24's Avatar
no, the high flow cat throws the code. I have the issue on my car too.
Get a CEL eliminator or turn it off in HP tuners. Or do what I do and ignore it
Old Mar 22, 2009 | 10:07 PM
EXsoccer1921's Avatar
what does the code read? don't feel like searching...i mean the description, not the numbers
slowswap's Avatar
How did you install a Vibrant downpipe on a CA header?
Old Mar 22, 2009 | 10:10 PM
chris88z24's Avatar
Welders make it happen.
Old Mar 23, 2009 | 12:21 PM
kevinj4891's Avatar
why? should there have been a problem.. they had a deal around christmas and i had to buy...everything matches up fine.The V2 header is a "shortty" and the vibrant d/p is kinda long..connects to stock resonator perfectly
what kind of "eliminator"? i tried the one from ARK and it didn't work. the spacer is too big and it wont allow the O2 sensor to go on cuz it hits the frame rail...no go. i got a spark plug non fouler and tried it..still get the code.
Last edited by kevinj4891; Mar 23, 2009 at 12:21 PM. Reason: Automerged Doublepost
Old Mar 23, 2009 | 12:33 PM
slowswap's Avatar
The Vibrant downpipe is shorter then a regular downpipe.
Old Mar 24, 2009 | 10:59 AM
kevinj4891's Avatar
then the V2 header must be a little longer. plus, i dont know if you guys realize, but i have a 2.4L everything fits perfect
Old Mar 24, 2009 | 12:20 PM
slowswap's Avatar
Exhaust are the same between L61, LE5 and LSJ.
Old Mar 24, 2009 | 12:24 PM
kevinj4891's Avatar
well, all i know is that it fits..
BACK TO TOPIC
anyone have an idea?
Old Mar 24, 2009 | 12:55 PM
rnjmur's Avatar
high flow cat = CEL
If nothing else has worked you will have to turn it off with HPTuners.
Old Mar 24, 2009 | 12:58 PM
D4u2s0t's Avatar
the po420 is for low catalyst efficiency or something similar to that. it's because of the hi flow cat. very common.
Old Mar 25, 2009 | 10:57 AM
kevinj4891's Avatar
alright...thanks...
its time to save up money and go for the trifecta...more power, eliminate code, and WOT!!!!!!
brandon04
Oct 21, 2015 07:04 AM
patooyee
Oct 15, 2015 05:11 PM
Iceberg
Sep 29, 2015 12:33 PM
Extremespeed
Sep 29, 2015 04:34 AM
Iceberg
Sep 28, 2015 01:31 PM
