Losing Pressure In Clutch...
I Have A Spec Stage 3+ And A Fadanza Flywheel...when Getting Into The Car When I Start To Shift My Clutch Gets Real Hard And Its Impossible For Me To Shift. I Have Relaced The Throw Out Barring And Slave Clyinder 3 Times..anyone Have Any Suggestions On What I Can Do To Fix This Problem?
Like ^ said, you just put in a performance clutch, it's going to be stiff as **** until you wear it in. Mine was stiff for a while too, I'm near 350 miles on it and it's getting much more driveable. Still more stiff than stock, but that's because the pressure plate is putting much more force on it.
well the pedal starts to go to the floor when i floor the gas...spec said i have a pressure issue..didnt know if a corvette master clyinder would fit or camaro...ect..
I have had the clutch in for 15000 miles
ye i don't know about the other master cylinders fitting our car, but it sounds to me like it is the master cylinder, but the good news is you don't have to drop the tranny to fix it, so it is about half as much to fix a master than a slave. this sounds like exactly what happened to me, except first my master went out then the slave. good luck mang.
i thought that we did but i was told no...but i just got the car back tranny was broke for 3 months b.c of not being able to shift...i broke a shift rod and top tranny mount and busted the ebow seal..
Sl0wbaltSS
Nov 21, 2018 11:11 PM
