Loss of power with A/C on...
Old Jul 29, 2011 | 08:32 AM
12tgood's Avatar
i drive a 2007 LS manual. whenever i have the air on it feels like i lose power. it takes longer to get my RPMs up and when i shift, the clutch/gas pedal timing is different. i know running A/C will decrease power but i also know it shouldnt be this bad. anyone else with this problem, heard of it, any ideas? please help me out here
Old Jul 29, 2011 | 09:16 AM
nhanson's Avatar
more than likely its normal but you could try cleaning your TB. JUST DONT OPERATE THE BUTTERFLY VALVE!
Old Jul 29, 2011 | 09:21 AM
USMCFieldMP's Avatar
Rattlesnake Race Shop
Perform some routine maintenance and it should help out (New spark plugs, clean the TB, new air filter).
Old Jul 29, 2011 | 01:07 PM
12tgood's Avatar
I've done all three within the last 2 months, and made the mistake of moving the butterfly, so I even got the ECU reflashed at the dealership, and none if it helped
Old Jul 29, 2011 | 11:45 PM
Malaclypse's Avatar
Yes... A/C dogs the little 2.2. Facts of life of owning a 4 cylinder. NA at least..
Old Jul 29, 2011 | 11:48 PM
cmatthewb101's Avatar
My LSJ does the same thing. Pretty sure it's normal. As stated above, welcome to owning a 4 cycl
Old Jul 29, 2011 | 11:50 PM
05Slowline's Avatar
um, lol, any car with the ac on is gonna dog it, my work truck is slow as **** to accelerate from a roll with the ac on and it's a 6. with an 8 maybe you won't notice it as badly, but you drive a 4 cylinder...lol.
Old Jul 30, 2011 | 12:58 AM
xdjstylz330x's Avatar
mine doesent do it that bad, but I do notice a low humming sound recently now. if I have the AC on high i dont hear it, but when i turn the fan to 1 setting i hear it. When I turn the AC off, it goes away. This just started happening this summer, think maybey my AC clutch is starting to go or something?
Old Jul 30, 2011 | 01:03 AM
nizzle's Avatar
sounds normal to me. AC robs power for sure and not just a couple. Your ac pump could be going out too. Maybe a bad bearing in the compressor or something idk
Old Jul 30, 2011 | 01:31 AM
07blackg5's Avatar
Slobodan Milošević
i moved the **** out of my butterfly valve, but it was removed from the car so idk if that matters
Old Jul 30, 2011 | 01:39 AM
rivaladore's Avatar
X2.....I also own a lsj and with the ac on plus it being hot as ***** the car isnt the peppiest. Every 4 cylinder I've owned have acted like this
Old Jul 30, 2011 | 01:51 AM
07blackg5's Avatar
Slobodan Milošević
my interceptor shows -21 vacuum at idle.
when i turn the ac on it drops to -16, and the engine load jumps up between 10 and 15%
pretty significant if you ask me
Old Jul 30, 2011 | 02:29 AM
BlackARCA06's Avatar
Yea i notice a difference, makes the car even slower. lol
Old Jul 30, 2011 | 02:37 AM
Murdered SS's Avatar
Me too i just clean the tb and i moved the butterfly valve alot but i also took it off first and unhooked the battery. I drove around the block and car was great didnt see or feel any problems.
Old Jul 30, 2011 | 02:39 AM
redcobalt07's Avatar
We are all acting like these cars produce a lot of power anyway.
Old Jul 30, 2011 | 02:41 AM
They do make alot of power especially when you have alot of stickers and overnighted parts from japan. lol
Old Jul 30, 2011 | 03:37 AM
dtowngreg's Avatar
windows down ftw
Old Jul 30, 2011 | 04:53 AM
sterba_10's Avatar
2-60 A/C for the WIN!
Old Jul 30, 2011 | 06:51 AM
Acey's Avatar
Noticed that even in the 2.4. Hated the extra revs needed to get going and the bogging, so I rarely used my AC.
Old Jul 30, 2011 | 11:25 AM
05Slowline's Avatar
Originally Posted by dtowngreg
windows down ftw
this
Old Jul 30, 2011 | 12:26 PM
Phil424's Avatar
Maintain steady throttle on a open stretch of road. Then, turn off the A/C. Its like getting a shot of NOS.
Old Jul 30, 2011 | 12:48 PM
dtowngreg's Avatar
Ecotec just kicked in yo
Old Jul 30, 2011 | 01:00 PM
You'll look like this
Old Jul 30, 2011 | 01:16 PM
Dart_SI's Avatar
I use my ac from a 40 roll so I get tracshuns.
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
ernnyyes
Oct 2, 2015 05:16 PM
717ssbalt
Oct 2, 2015 04:01 PM
Stuff
Oct 1, 2015 05:47 PM
