Lost all gears! Help
Old Jan 28, 2011 | 06:31 PM
nate_88's Avatar
I have a 2006 Chevy Cobalt SS, and about 2 months ago I was driving through the snow and heard a slight bang come from underneath. Ever since that point, 2/4/R were slightly tough to get into. It became worse as time went on. Today, 1st became a little rough, 2nd gear went out, so I had to go right into 3rd. Tried to compression brake coming to a stoplight into 2nd gear and had nothing there again. When I went to leave the stoplight, I had no gears whatsoever, and still can't get into them, not even Reverse. I put the car on some jackstands to check the linkage, and the linkage is on and the shifter moves the top and bottom linkages. What I did notice was there's pressure moving the shifter left and right, but it feels like it "free-*****" top to bottom with no resistance. I did notice the roller pins on the top linkage are sticking out slightly over a 1/16", maybe an 1/8". I still have fluid in the master cylinder and pressure in the clutch Would I lose all gears if the top roll pins are broken? What else could be wrong? Any help would be appreciated.
TIA,
Nathan
Old Jan 29, 2011 | 11:18 PM
nate_88's Avatar
Roll pin shattered. Replaced it today and it shifts better than when I first bought it!
Sl0wbaltSS
Nov 21, 2018 11:11 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
biniecki
Oct 25, 2015 02:23 PM
MrInsanityWolf
Sep 29, 2015 04:54 PM
DocSvensk
Sep 27, 2015 02:24 PM
