Low Fuel Warning
Old May 15, 2007 | 03:00 PM
RonSS's Avatar
Low Fuel Warning
So,
Knowing the car was a bit low on fuel, I set the display to show miles remaining and drove to work 15 miles. Gauge was right at 1/8 tank.
When I left, it said 55 miles. A short while later, it said 51 miles. Then back to 55 miles. Then to 47 miles. Next came the low fuel warning and the gauge was at empty???
Mostly all level ground stop and go morning traffic.
So, better go fill it up at lunch to avoid the hassle of doing it on the way home. Fire the car up, fuel gauge is at 1/8, and the readout says 55 miles left???
I'm thinking the fuel gauge don't know Jack! Nor does the display.
Cruise Control quit again as well.
A little tired of taking the car to the dealer.......it's a hassle!
Ron
Old May 15, 2007 | 03:13 PM
Tomtwtwtw's Avatar
Once you get below ~40 miles left, the gauge will read empty and you'll start getting your low fuel warnings. You still have 40 miles left, but it's letting you know that there's no extra reserve hiding anywhere.
SSdan's Avatar
Hahaha i would be all wtf?!?!?!
Old May 15, 2007 | 03:18 PM
Witt's Avatar
Either a computer issue or a problem with a switch near the clutch more than likely.
Old May 15, 2007 | 03:30 PM
css9450's Avatar
I think the less gas there is remaining in the tank, the less accurate the display is. All cars are like that.
RonSS's Avatar
I'll check the owners manual and see what it says about the low fuel warning.
i'd prefer the gauge not going to zero suddenly when there is fuel in the tank.
Cruise control? Sounds like some folks have simply reset the ECM. The dealer replaced the clutch switch a few weeks ago.
Ron
Old May 15, 2007 | 03:47 PM
LSCobaltlover05's Avatar
I know for mine the low fuel warning usually comes on when about 2 gallons are left... or when it says i have 50 miles left to go.
Old May 15, 2007 | 03:49 PM
Jimmys2007CobaltSS/C's Avatar
i usually never let it go down to E...when it hits quarter tank i go fill her right back up
Old May 15, 2007 | 03:50 PM
07cobaltowner's Avatar
mine does to low fuel right at 40miles, then just like yo said it jumps down to zero really damn quick. pisses me off. i figure that once i get to an 8th of a tank im at zero, thats my moto
Old May 16, 2007 | 01:14 AM
sensesfail99's Avatar
I have a simple solution for your gas light problem... DONT let it get that low.
DarrenGC
Forced Induction
Jan 2, 2016 09:10 PM
no_ss
Oct 18, 2015 11:58 PM
Slick_Nick
Sep 28, 2015 09:15 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
