lsj boost issues
Old Jan 11, 2014 | 01:44 AM
bluess26's Avatar
lsj boost issues
so every ounce in awile when I get on it it will try to boost but kinda boogs and doesn't boost other times it boosts fine any ideas?
Old Jan 11, 2014 | 02:06 AM
SPDDMN36's Avatar
Worn out bypass solenoid?
Old Jan 11, 2014 | 02:13 AM
jp1600's Avatar
Check the butterfly valve on the supercharger, you have to take of the sc to get to it
Old Jan 11, 2014 | 03:03 AM
bluess26's Avatar
how do you test it to c if its working?
Old Jan 11, 2014 | 09:03 AM
mrbelvedere's Avatar
try posting this in problems and service
google the boost bypass mod
Old Jan 11, 2014 | 10:56 PM
bluess26's Avatar
I just did but no replies
Old Jan 11, 2014 | 11:18 PM
google the bypass mod and try it
Old Jan 13, 2014 | 12:47 PM
kobe77's Avatar
Didnt work for me. All plugging that hole did was give me a fucked idle to the point where it would stall out.
Old Jan 13, 2014 | 01:24 PM
jp1600's Avatar
Vac leak
Old Jan 13, 2014 | 01:39 PM
Olybaltss's Avatar
If you haven't figured it out yet, the search function on this site is screwy. bad.
your best bet for any css.net searches is to actually go to google, type your search, and add cobaltss or cobaltss.net to the end of the google search.
Old Jan 13, 2014 | 03:15 PM
jp1600's Avatar
site:cobaltss.net will search just the forum
Old Jan 13, 2014 | 05:01 PM
bluess26's Avatar
yea im not gna try that lol that's what I read
Old Jan 13, 2014 | 05:10 PM
kobe77's Avatar
Originally Posted by jp1600
Vac leak
Must be. Im getting gm to pressurize the system this week cause i dont have garage space or any of the **** to do it. i got the car to idle fine tonight after 10 minutes of ******* with it. idles good when shes warm
Old Jan 13, 2014 | 06:08 PM
then you did it wrong or you got a different problem
there are 2 things that control it 1 is the boost bypass solenoid and the boost bypass actuator by correctly doing the boost bypass mod you take the solenoid out of the circuit and then that leaves the boost bypass actuator if you disable the solenoid by removing the vacuum source and you still have a low pressure problem then you either have a bad actuator or cracked vacuum lines or a stuck open butterfly on the blower
Old Jan 13, 2014 | 07:20 PM
jp1600's Avatar
told him to take the blower off and check, but i think this was looked over.
Old Jan 13, 2014 | 09:13 PM
bluess26's Avatar
yea im deff gna check that out and make sure no vac leak
Old Jan 13, 2014 | 09:14 PM
bluess26's Avatar
o ok I get what u are saying I googled it and it was coming up with everyone that said there car ran worse after
Sep 27, 2015 08:53 PM
jmelton327
Sep 26, 2015 10:04 PM
Coballin13
Sep 25, 2015 08:43 AM
