LSJ Boost Problem... maybe.
Old Apr 6, 2008 | 04:40 AM
USMCFieldMP's Avatar
Rattlesnake Race Shop
I think I have a problem. Mods:
Fujita CAI - Stg2 - 2.8" pulley - GMPP Header - ZZP 2.5" catless DP - GMPP Performance Cat-Back - Wicked Tune
I installed my ZZP CATLESS DP and I'm still hitting 17.5psi, and almost instantly too. I noticed it today when I shifted to 4th, it went straight to the 17.5psi line. It worries me... I wouldn't think I should still be hitting that much boost with a catless dp. I wonder if its just the cold air combined with the very slight Port & Polish I gave my TB.
I think it is my Intercooler. Ever since my IC Pump failed in October... I've been hitting 17.5psi... on the dot. Before the IC Pump failed, I had a C/A 2.5" DP with an empty cat... and I would only hit like 16 or so PSI... never 17.5... BUT my local dealership is full of idiots... so I don't think they would be able to figure it out. I ran that blown IC Pump for a Month because they didn't think that was the problem... even after I told them that it was. They warrantied my EMPTY CAT, AFTERMARKET DP with a stock replacement because they thought the problem was that it was clogged, causing too much back pressure... which made the coolant shoot out of the IC Overflow... Right.
And ever since the pump went... I have been hitting 17.5.
SO do you guys have any suggestions? DO you think that the excessive heat from having no IC pump might have screwed up the Laminova's in some way? Causing extra boost?
Anybody? Anybody? Anybody?
Last edited by USMCFieldMP; Apr 6, 2008 at 04:40 AM. Reason: Automerged Doublepost
Old Apr 6, 2008 | 04:55 AM
SlowBalt_06's Avatar
sounds normal with a 2.8 and plus the porting will help that too..throwing no codes or anything i wouldnt worry bout it
Old Apr 6, 2008 | 05:09 AM
I dunno... before the intercooler problem, I never hit 17.5psi... I doubt I was even hitting 17. But now, its straight to 17.5. I polished up the outlet of the S/C and did the TB... so I can foresee getting a little bit more pressure there, but BEFORE I put the Catless DP on there... I was hitting 17.5... and now, with the catless dp... I'm still hitting 17.5. I dunno. It still pulls... good enough to whoop Mustang GT ass.
Like I said... I would think that the Catless DP would drop the boost big time... its just physics... or some other science/math .
Old Apr 6, 2008 | 05:13 AM
ItalianJoe1's Avatar
Normal, my car gets the same thing, same 2.8, same catless exhaust.
Old Apr 6, 2008 | 05:19 AM
Sweet. I was worried. I never hit 17.5 on my old DP. Maybe that tiny port job I did really helped out a lot. I'm sure that cleaning all of this junk off helped a lot too!
Old Apr 6, 2008 | 05:22 AM
Yucky.
Yeah, removing that gunk might have helped, I have a ported/polished TB on mine, along with a ported intake mani. I was doing a pull coming home wednesday night, and the boost never went much over 17, all the way up to 140 in 5th.
Old Apr 6, 2008 | 01:05 PM
Omega_5's Avatar
I got your PM.
I'm not sure that it's the IC that's causing the boost to peak higher. If they were damaged, your IAT2's would be thought the roof, and you would have next to no power, cause the car would be pulling timing like crazy.
It could possibly be the fluctuation in air temps (I know I see weird stuff in the spring).
The P&P on the TB could play a small factor as well, as it decreases the likelihood of hitting abs. vac. in the TB.... but I can't see it accounting for 1.5psi.
If you have HPT, maybe throw up a few scans, and see if we can get a better feel for the problem.
Old Apr 6, 2008 | 11:58 PM
rukkee's Avatar
How many miles are on your car? I cleaned my TB at 18,000 miles and it wasn't nearly that bad. Not that it has anything to do with your boosting issue but your crankcase pressure might be high.... blowing oil from the breather into the intake? It looks like it's time for a catch can.
Old Apr 7, 2008 | 07:28 AM
50k Miles.
The CAI was nasty too... but it was like solid mud in there... opposed to the oil like substance on the TB.
I haven't had my Dipstick pop out... but when I looked at it today... I noticed that there was oil ALL the way up my dipstick... like it had been shot up it.
It did run like ***** today... and was acting F'ing weird... I'll start a new thread... but I'll post the video here too:
http://s138.photobucket.com/albums/q...t=20080406.flv
It did this the entire time I had the car on. I turned the car off... checked all fuses and PCM/ECU connections... then started it up 15 minutes later and it ran fine... just sluggish as all hell (maybe because of the heat... but this was BIG time sluggish, like "I don't think I can beat that stock Civic Si right now" sluggish.) So I went to a store. Car off... went in. Came out... started it up... and it did that gauge **** again!
Turn it off & restart it 3 times and finally it was fine... only now when I punched it... it like hesitated for 3 seconds and then BAM! wot... and it actually pulled hard.
Blah Blah Blah. Its pissing me off. I go to work, come home... and its doing the gauge **** again, as soon as I pulled into the driveway. **** that car.
06MetallicBalt
Jul 20, 2025 08:47 PM
Supercharged06SS
Dec 11, 2022 04:47 PM
DarrenGC
Dec 24, 2021 01:55 PM
Jan 12, 2016 12:01 AM
